16-01-2013, 02:03 PM | #61 | ||||
Life begins at 40
Location: Melbourne. Socialist capital of Victoriastan.
I’m not sure if the mods were carried out before of after the purchase but remember seeing a brochure many years ago at a Holden dealer. I remember them costing big dollars in their day.
Justice is what you get when you run out of money.
16-01-2013, 04:39 PM | #62 | |||
And, what I was trying to get at was that if it were a TWO tonner, it would be called that, not a two ton One Tonner? a bit like a 6cyl GTHO. |
16-01-2013, 05:08 PM | #63 | |||
AFF Whore
16-01-2013, 06:52 PM | #64 | |||
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
16-01-2013, 06:57 PM | #65 | ||
The oil pump parts that are just soft mild steel and should be about 60 Rockwell hardness , poor guys that put these in
Oh and counterfeit bearings they are everywhere now
Fords are cool Last edited by 123Cat; 16-01-2013 at 07:02 PM. Reason: Add |
16-01-2013, 07:08 PM | #66 | |||
AFF Whore
17-01-2013, 12:55 AM | #67 | ||||
regards Blue |
17-01-2013, 02:58 AM | #68 | ||
17-01-2013, 10:34 AM | #69 | ||
While working on printing presses the new boy would be sent up to the fitters shop for a "long wait" or into the plate makers for a "box of highlight dots" or over to the ladies in the binding section for a "DV8"
Pete |
17-01-2013, 11:42 AM | #70 | ||
Unintended Perfectionist
Twin overhead foxtails
Once had a mate certain he had a V8 with 6 cylinders.... Fast running bubble fluid, as apposed to slow running bubble fluid.
BA-FG parts for sale. http://fordforums.com.au/showthread.php?t=11411117 http://s1092.photobucket.com/user/my...?sort=3&page=1 The XR re-erection in the works http://www.fordforums.com.au/showthread.php?t=11386452 |
17-01-2013, 11:58 AM | #71 | ||
Rotaries DO actually have oil rings!
I can vaguely remember an ad in the Trading Post (when it was in print and came out fortnightly) back in the early "80's for an RX? with a worked 13B that had a "Lumpy Cam,Chev roller rockers,over-sized valves...." and the phone number for a bloke who "was a shift worker so only call after midnight...." |
17-01-2013, 03:40 PM | #72 | ||
17-01-2013, 04:19 PM | #73 | ||
[QUOTE=2011G6E;4591343]Not all "fake and made up car mods" are actually imaginary...some are a physical object that empties peoples wallets. (and yes, I'll say "HiClone" again)
Shamefully, I must admit I once spent good money...about $40 when I was only taking home $200 a week...on a "spark enhancer" that a guy at the local show was selling. He had a then fairly new WB Statesman (this was back around 1982 when I had just started drivingbut obviously my common sense hadn't developed sufficiently yet )) with a 308 in it. The "spark enhancer" was a cylindrical object, plastic, finned on the outside, and with a male connection sticking down from the base and a female connection at the top. The way it "worked" was to remove your coil lead, plug this thing into the top of your dizzy, then plug the coil lead into that. That was it. No extra energy in, so by the laws of physics it can't work to make your spark "bigger". He had a very impressive setup of a glass box with a sparkplug sticking into it and a dark background (to see the spark gap), and he had a power box with a spark plug lead going to the plug in the top of the box. He would turn it on, and it would spark away regularly like a spark plug does, and then he would turn it off, put on the "spark enhancer" and turn it on again. WOW! The spark was much bigger! Amazing! Shut up and take my money!!!! He was doing a roaring trade. Of course, none of us considered that perhaps the switch he turned on was a two position switch, with a weak spark for the pre-fitment of the magical device display, and another with a stronger spark output for after he fitted the device... Sadly me too and about the same year also
Current Ride :Tangerine scream st focus |
17-01-2013, 07:21 PM | #74 | ||
FG XR6T trayback
[QUOTE=noosacuda;4592641]Rotaries DO actually have oil rings!
[QUOTE] Rotor seals but not rings, as such. |
17-01-2013, 07:28 PM | #75 | ||
18-01-2013, 09:59 PM | #76 | ||
Direct Exhaust Injection....
1999 AU XR8 - Series 1 Manual
Tickford Options: Tickford Bodykit, Sunroof, Momo Steering Wheel, 17' Alloys Check out my blog on OBD-II Diagnostics Including ELM327 & The Nifty Carecar C68 @ toneboi.weebly.com |
18-01-2013, 10:29 PM | #77 | ||
2 users like this post: |
19-01-2013, 12:21 AM | #78 | |||
Where to next??
He installed this device, which could well have been called a Spark Enhancer as well and then had the car running quite well on 3-4 cylinders if memory serves! Or something like that.. it was probably 10-12 years ago now! http://www.youtube.com/watch?v=PspgwbkcSeM
___________________________ I've been around the world a couple of times or maybe more....... Last edited by Yellow_Festiva; 19-01-2013 at 12:26 AM. |
12-09-2013, 12:19 PM | #79 | ||
Missing a sock...
Just came across another BS power enhancer while I was searching Gumtree - JETPIA. This ones a ripper - seven years R&D!
This device fits over your tailpipe and "JETPIA makes the condition conducive to efficient combustion by reducing the back pressure in the exhaust system". Well, FMD! You simply introduce a restriction to your exhaust system to reduce back pressure! Throw away your extractors, hi flow cats and mandrel bends lads - you've been doing it wrong, and at the wrong end for years. Just look at this incredibly simple design - a picture is worth a thousand words. The theory would be too hard to explain in writing to a lay person: I'm off to wherever good JETPIA's are sold right now! http://www.jetpia.com.au/ Cheers!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
12-09-2013, 02:02 PM | #80 | ||
AFF Whore
Wait... so a decrease in exhaust pipe diameter causes the exhaust gasses to flow faster because there are some holes in the tip that 'suck' air in, thus aiding in exhaust velocity??
Looks like a glorified 'fake turbo whistle' device |
12-09-2013, 02:14 PM | #81 | ||
Hmmmmm
Spirit level bubbles
12-09-2013, 02:31 PM | #82 | |||
Life begins at 40
I’m buying ten of them. Imagine the power increase when you put one in front of the other.
And in the words of Homer Simpson… eat my rust.
12-09-2013, 02:51 PM | #83 | |||
SY TS AWD LPG TEZZA
Personally I like the $15 electric turbocharger kits. Essentially a 12V hair dryer you shove into your throttle body. Great for another 100kW at the wheels.
1st car 75 XB Fairmont wagon 302C converted to 351C. 2nd car 82 ZK Fairlane 351C 4spd AOD LPG/Avgas 3rd car 97 EL Falcon police car 4L auto dual fuel 4th car 90 XF ute (work car) 5th car 06 SY TS AWD Territory Orbital LPi 6th car 95 XG ute 7th car 2014 SZ Territory TX Petrol Fords all my life. |
12-09-2013, 04:06 PM | #84 | ||
Call me 'Al'
Location: On a flattened-out cardboard box out the back behind the wheelie bins.
Or as Clark Griswald says "Burn some dust! Eat my rubber!"
What about those braided hose 'socks' you could get to stick over your regular hoses? Population tools, rubbers, socks and hoses... Great thread |
12-09-2013, 04:23 PM | #85 | ||
BIG MEMBER ;)
2010 FG XR6T, EGO, MANUAL, LUXURY PACK.
12-09-2013, 06:37 PM | #86 | ||
Whoa, this is heavy!
I had one of these a while ago....had it on the my little mk1 golf for giggles, then put it on the crummy old diahatsu delta at work.....puts out a hell of a whistle on a little diesel truck donk, the bloke I worked with loved it, if I was coming to help on a job he could hear me whistling streets away
Liquid Silver 2002 AU III Fairmont wagon Le Mans Red 1990 SA Capri Turbo
12-09-2013, 07:50 PM | #87 | ||
Jim
Work experience kids are great fun when I was working at a wreckers many years ago now... Just trying to remember some of them that have not already been mentioned....
Front springs for a Valiant... Speedo cable for an XD Falcon Tailshaft for a Ford Laser (FWD) Can of End Float... Copper Plated Magnet... There are probably lots more... And the fun of unbolting a rear door of a car, putting it back in place and getting the guy to go get some part out of it... Friggin Priceless....
The Daily. White 2017 ZG Escape TDCI AWD Wagon The Wifes. Grey 2015 MD Mondeo TCDI Hatch The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread |
12-09-2013, 08:46 PM | #88 | ||
I work at an airport, story will not make sense if you don't know.
We had a young bloke who worked near us come in chasing a meter of flightline. He couldn't work out why we all started laughing so hard. Poor fella. |
12-09-2013, 09:17 PM | #89 | |||
I once got sent to buy a bottle of prop wash. |
12-09-2013, 11:43 PM | #90 | ||
I sent my apprentice to another department, of the mine I worked at, for a "Long Weight". The bugger was away for 2 hours before the chief engineer chased him back to me. Just don't send a kid to the blacksmith for a solid punch.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better! |
