24-03-2006, 10:10 PM | #61 | ||
If I'm not wrong..I think the true jungle fighter is a ghurka?
Who cuts your throat in total silence.
FORD RULES OK The more I know ppl the more I love my DOGS. 2011 SY Territory Limited Edition TS 2000 AUII SE ute IL6 |
24-03-2006, 10:13 PM | #62 | ||
ba xr6 mk1
Isnt this about air rifles.
25-03-2006, 02:33 AM | #63 | |||
25-03-2006, 10:06 PM | #64 | |||
yep Lil Johnny knows all about wmd's....look at the new IR regs/laws
01-04-2006, 11:21 PM | #65 | ||
The air-soft rifles and pistols are legal in some states of the US, not sure how many. From all the looking around I did you just needed to ensure it had the orangeg bit on the front to ID it as not real??? WTF, pitch black a cop won't know the difference or a small amount of black paint, and no more idea. Rang customs cause they said you can bring these bad boys in with a permit on their website but got a very blunt no from the lady on the other end of the phone.
Current: 2016 Camry 1966 Mustang Coupe Previous: 2011 SZ Territory Titanium 2008 Ford Edge AWD Limited Silhouette BF XR6, ZF Auto White EF GLi, XR look alike VH Commodore |
02-04-2006, 12:34 PM | #66 | |||
Grinder+Welder = Race car
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear" - Too much power is never enough....Mark Donohue on the Can Am Porsche 917. |
02-04-2006, 02:54 PM | #67 | |||
The M4 shot about 2 inches lower at 300m depending on ammo used. The M4 was a 1/7 twist so it did not like M193 (55g) ammo and the M16 was 1/14 so it hated SS109 (62g). The AR was 1/10 and ate both happily. All 3 rifles would easily shoot a 2 inch group off hand at 100m. My MP5 was great up to 50m and I could hold a 30 rd burst in a 30cm circle at 25m. It was fairly hopeless at 100m as by that distance it had lost most of its velocity and became a bit eratic. Did you find these results with YOUR guns or are you just quoting out of magazines articles? |
02-04-2006, 03:54 PM | #68 | |||
The English had the same problem in India and Africa, hence the .455 Webly Manstopper soft nose ammo had "Not for use against Civilised Combatants" on the packet, having been intended primarily for maximum stopping power. The Americans had a similar problem in the Phillipines, they were figthing insurgents that combined body binding and stimulants and found they needed more stopping power..
02-04-2006, 04:46 PM | #69 | ||
A MP5 fires a 9x19mm round (there are 10mm & 40cal but these are rare).
The muzzel velocity varies between 900 and 1300 feet per second depending on weight of projectile (115g-180) and load. The gun does not function well with extra hot loads as it uses a delayed roller lock system. In a vacuum where there is no drag on the projectile it will take between about 0.8 and 1.1 seconds tp travel 300m. During this time it will drop 8 to 11 metres or between 4 and 5.5 "people heights". So in a vacuum you would have difficulty shooting as the target would be completely hidden by the foresight. Normally the weapon is used in air. The projectile used in a 9x19 cartridge is a round nose flat base FMJ or JHP. This has sigmificant drag and the velocity will drop off quite quickly causing the actual drop to be in the order of 15 to 20 metres depending on air pressure, wind, humidity, actual proj used etc. Once the velocity of the projectile drops below its critical value the rotation becomes unstable and the projectile tumbles causing eratic behavior. It will not group at that distance. I did this stuff for a living for over 10 years and am still a qualified armourer (although I am out of the industry). I have actually owned and used the above firearms in test, competition and hunting senerios and I can tell you that a M4 will drop a pig bigger than me at 250m with a single round because I have done it. Have you actually used any of this stuff? And if so where? |
02-04-2006, 08:07 PM | #70 | ||
Ich bin ein auslander
MP5 out to 300m, stop it, you are killing me! The MP5 fires glorified pistol ammo that is worthless past 50m. Any one that has any experience with it will tell you the same.
At 100m, a wet great coat (big heavy woolen coats we used to have) would probably keep you safe from 9mm. An example is the discreet lightweight vests used by security forces will stop 9mm, it takes big heavy kevlar ballistic armour to stop 5.56mm. Best you check your sources. As for special forces, I am not gong to enter this too much as for me to do so would require that I commit a federal offence by exposing secret information over a public forum (not worth jail time). I will leave it at this, I have served in special forces units and can tell you that you are very wrong in your information of what calibres are used where. I would suggest that Guns and Ammo is not the definitive information source that you believe it to be.
Growing old is compulsory, growing up is optional! |
02-04-2006, 08:30 PM | #71 | ||
Turbo Falcon Fiend
Me pull trigger, gun go bang.
I imagine getting hit by anything isnt good. I would imagine the ballistic energy of a 9mm round is pretty poor after 100m, I have a .310 Cadet that is probably ballistically superior to a 9mm, and let me tell you after 100m, medium sized game dont need to be too scared. Lately I have fallen in love with fast .22's, the 22/250, the .220 Swift etc.... I have a really soft spot for my .22 hornet - that is a much underated round. I still love using black powder too. My flintlock gives me hours of fun and frustration. Since this thread has been well and truly hijacked, is anyone else a bit of an enthusiast?
Too many turbo toys...... 2009 FG F6 Nitro LPI LPG 290rwkw on LPG. 2005 BAMKII XR6 Turbo with LPG (ex HWP 255,000k's and counting) Honda 2001 CR500E Road registered CR500 Honda 1985 CR500 (the one with the arm ripping power) DT200r regoed Hack Yamaha IT/YZ 465 Vinduro rocket Imported IT465 and 490 back up bikes VF1000R mid 80's racer built by HMR Honda CR480 Air cooled project road cafe racer. T88 Turbo XT Falcon project with 351 Cleveland (mothballed) Plus the rest. . |
02-04-2006, 09:50 PM | #72 | ||
Weezland
Yep, my current favourite is my weatherby accumark, carries like a mountain rifle but shoots like a range rifle
02-04-2006, 10:19 PM | #73 | ||
I did say the MP5 comment was an exaggeration.
However you don't go chopping 6" off a barrel without compromising your performance significantly... 5.56? soft kevlar won't do it except at extended range.... I have to say I really don't envy anyone who spend much time in kevlar with the interceptor plates, I know spending all day in an EOD scout vest is bad enough (although its probably the same weight as a tactical vest with the ceramic plates in it given the extra shoulder/throat/crotch flaps) I think i've hit a point where i'll just keep my trap shut cos I know what I know, and i can't be bothered getting into it any deeper on a public forum. As for "Guns and Ammo", I can't say i've ever read it.
03-04-2006, 12:58 PM | #74 | |||
Scrubber Racing Team
i got a nice anschutz .22 hornet, beautiful rifle |
03-04-2006, 09:56 PM | #75 | ||
Turbo Falcon Fiend
Nugget, what cal is your weatherby in?
ssb Anschuzt are great, I love the german stuff. I recently picked a a 5 shot bolt action Walther hornet, the one I use all the time is a little CBC single shot break barrel, it has a tasco 2.5-10 mil dot scope and harris bi pod, it is awsome out to 150m, and good out to 180 or so.
03-04-2006, 10:01 PM | #76 | ||
i just got a 6x40 c-clear scope on mine, the rifle is set up with a hair trigger and is good for headshots on our smallish eastern grey roo's for 150 odd meters, very smooth bolt good for rapid fire on goats. the walther would be a nice piece of kit
