Old 02-09-2019, 01:00 AM   #31
cobrin
Challenge Accepted!
cobrin's Avatar
Default Re: Replacing MB rear brake pads
There's actually two forces you need to do, turn and (equally important) push at the same time. If you're not pushing on the piston it won't retract. You don't have to open the bleed screw, it's not needed.
To be clear, push as you turn and it should return.
Undecided replacement...
[SOLD] -2009 MB Mondeo Zetec TDCI- [SOLD]
cobrin is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2019, 08:21 AM   #32
bundybear75
bundybear75's Avatar
Thanks Cobrin, I tried pushing as I turned - obviously not hard enough....
I was using one of those cube style wind back tools, and I cannot get a lot of force on the piston.
I have ordered a wind back kit off eBay, should be here Wednesday. Hopefully it will go back with a little force. It does turn clockwise to wind in doesn't it?
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2019, 10:07 AM   #33
cobrin
Challenge Accepted!
cobrin's Avatar
I think I did clockwise for both sides, didn't really think about it, just pushed as I turned and it started to move back in noticeably so by the time it completed a full 360 it were done.
Old 02-09-2019, 11:59 AM   #34
bundybear75
So one rotation should get it there?
I would of turned mine dozens of times. I initially started with a pair of needle nose pliers and I though it moved in a little. When I changed to the cube tool, there was no noticeable retraction at all.
The piston was a long way out, the pads had just got to the grinding noise point so next to no friction material left on the inner pad. Hopefully hasn't gone past some stop.....
2002 BMW R1150GS
Old 02-09-2019, 02:43 PM   #35
NZ XR6
I tried initially with needle nose pliers, but it soon became apparent that wasn't going to work. I put the old pads in and left it for another day.
But when that day came (metal scraping sound), I had an elbow injury and had to pay someone to change them for me.
I've read in a couple of places that the cube tool doesn't work on the Mondeo and you need the proper retractor.
MB Mondeo TDCi wagon, sea grey, on MAK Invidia 16" wheels.
NZ XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2019, 09:18 PM   #36
cobrin
Challenge Accepted!
cobrin's Avatar
I think so, but that would also be conditional to how hard you're pushing and if you had opened the bleed valve on top of that. From what I remember it were pretty straight forward but my pushing force may be harder than some, but it weren't insurmountable.
Old 04-09-2019, 01:14 PM   #37
rondeo
The special tool has a reaction plate which pushes against the other side of the caliper as you wind it in:
https://www.ebay.co.uk/c/1831725779
https://www.youtube.com/watch?v=85Qan0Co9mc
At least remove the brake fluid reservoir cap to release pressure. I just opened the bleed nipples when I did mine.
rondeo is offline   Reply With Quote Multi-Quote with this Post
Old 04-09-2019, 01:36 PM   #38
bundybear75
This one should be waiting for me at the post office this afternoon.
https://www.ebay.com.au/itm/332757473275
I tried both opening the cap and cracking the bleed nipple. I couldn't get enough force to push back and turn by hand the piston.
Hopefully I can sort this out this afternoon - its costing me $50 a day to drive my Landcruiser to work.......
2002 BMW R1150GS
Old 04-09-2019, 05:54 PM   #39
rondeo
My concern was not to make it easier to wind the caliper in but to avoid possible pressure build up in the reservoir. Opening the bleed screws I thought might avoid pushing crud back into the lines, two birds.
Anyway, good luck!
Old 04-09-2019, 06:40 PM   #40
bundybear75
Well what a difference the right tool makes.
I spent a whole afternoon trying to do the first side, finished it in 10 minutes today and i reckon it took 15 minutes to do the other side.
Don't try this without a proper tool would be my advice.....
Thanks everybody for your advice.
2002 BMW R1150GS
