Old 07-11-2011, 08:33 PM   #31
TheZHLANE
TheZHLANE's Avatar
Default Re: xb et 13.10 need help to crack 12s
Originally Posted by prasac
i have tried a few calculators for power to 1/4 mile. this is probably the best online 1/4 claculator i have seen. it's pretty spot on with the Moroso also http://www.rx7.com/accel_calculator.html
This is actually a perfect calculator, only 1mph out on my chart and et was exact
RIDES
76 ZH Fairlane 500, Mushroom Beige, Brown vinyl roof, 351 c4 13.361 @ 104mph 2.001 60ft 208rwkw
ZH BUILD
TheZHLANE is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2011, 06:27 PM   #32
adz790
maybe strip some weight off her i.e spare tyre reo bars... helps
adz790 is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2011, 06:08 PM   #33
ash68
make sure your not sitting in the middle of the water when you do your burn out get some one to guide you to the edge of the water .because it builds up under your guards then drips down onto the start line.also work out a routine and stick to it .good luck
ba xr8 ute 11.69 118 manual. stock motor .nos .
1.55 60ft
ash68 is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2012, 10:42 PM   #34
Rural 351
1000+ passes
Rural 351's Avatar
Originally Posted by falconsmurf
set up
xb falcon 3700lbs
351ci approx 217rhp 318lbft@5260
2v heads 4v valves
crow 21649 cam 108/234/244
pedders 90/10 front shocks
pedders soft rear shocks
3800rpm stall
3.89gears
funnel web/850 demon
shift kit
275/15/50s 27high
60ft......1.99
330ft.....5.48
660ft.....8.42
1000ft...10.97
et13.10@102.72
i cant hold stall over 2000rpm on line without breaking was thinking of transbrake though may not suit my combo currently redline over finish line,set tis what is just chasing 2 tenths maybee caltracs?carb is big i know also have 150 n20 shot not ran.all ideas welcom.
You cant avoid it your cams to small, I did a similar motor for a mates XB 4 door had a crow (21823) 249/258 @ 50 109 lc around 620 lift 850 carb active manifold small converter about 3000 rpm ( could only hold just over 2000 on the line) it ran 12.6 107mph, I think you should do a cam change even with your small stall conveter you will pick up a few tenths,
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph
https://www.facebook.com/DragRacingT...2067110055900/
http://www.cacklingpipes.com/100825_...250810_025.JPG
XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph
The faster youve gone the worse your attitude
Rural 351 is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2012, 02:32 PM   #35
jcxr
Tribal Elder
jcxr's Avatar
and with gas
3 degrees base
710nm 523ft/lb
236kw 318hp
131kmh 5470rpm
et was at heathcoate 3 weeks ago with no gas
If that 3 degrees is your base or initial timing, there is your problem. Seems very low.
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2012, 05:50 PM   #36
El Caco
Steve
El Caco's Avatar
I'm surprised no one picked this up
(Torque x rpm)/5252 = HP
(318 x 5260)/5252 = 318.48 HP
El Caco is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2012, 10:03 AM   #37
red80
red80's Avatar
When we were playing with relatively slow cars as teenagers we used to drop the fan belt off before the run and push it up to the line. Do the pass then put it back on on the return road. This was only in Geminis and escorts that ran 15 and 16 sec times but usually dropped a few tenths. Air cleaner off? Back seats out? Tyre pressures? Slicks would help but there are plenty of cars running consistant quicker times on normal street tyres. I used to run reasonably consistant low 12's with 195 street tyres in a turbo rotary escort (don't laugh it was a lot of fun)
red80 is offline   Reply With Quote Multi-Quote with this Post
