24-03-2008, 10:22 PM | #31 | |||
you can get them to open all the way up by simple bending the little metal stopper thing on the front of the bbm where the vacume hose fits it.i'd recomend pulling the top of the bbm off to get it right ,or you could go to far and end up closing them slightly the other way.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
24-03-2008, 10:27 PM | #32 | ||
yeah i see, i will look into that tommorow FS5
24-03-2008, 11:02 PM | #33 | ||
I build your wish list...
FS5 You are on the right track
all you have to do is look at it and you will see how they are still restricted . I was told about 2 years ago after I did a cyl head for a guy he took it to G&D and they chipped and tuned it then even they said the manifold was the restriction in his motor build that it just had . I Bent the leaver at the front of the bbm to get a extra 6 rwkw . this is very old news and I would have really thought that a lot of you guys would have all ready done this as all it takes is a small hammer and 10 sec of your time |
24-03-2008, 11:43 PM | #34 | ||
any idea exactly how much of a "bend" this requires to give max gain??
would rather not rip off my BBM upper 1/2 just to look for 2 mins lol cheers for the tip tho trick_xd
25-03-2008, 01:54 AM | #35 | ||
seems crazy but it only needs about 2 - 3 mm
in doing this you most likely find that the surge when the bbm opens ( atm should be around the 2,500rpm mark ) will be a bit later by about 500 - 700 rpm . at this I have no real answer but for the time it takes to open the valve in the pod still opens the same but the leaver is bent so it thinks it has started to open when in fact it is not. I hope you understand that ..... I don't make sense a lot of the time . |
25-03-2008, 08:00 AM | #36 | ||||||
RIP...
Secondly, the point at which it does open is 3800RPM, not 2500RPM. Quote:
Rick.
. Oval Everywhere... |
25-03-2008, 05:58 PM | #37 | ||
yeah im confused now, i see what you mean the valves at wot are only 3/4 open!!, i heard that if you do adjust them you will feel the kick a little later 4000rpm mark, at the moment my car get this real huge rush at 4000rpm anyway so i dont know
25-03-2008, 06:50 PM | #38 | ||
I don't know how you work out that it opens at 3800rpm
I plant my foot and it starts to pick up at about the 2400 - 2600 mark , maybe it has to do with your cam? Joe I have stuffed around with a heap of these bbms as you know I was the first to cut 1 up and flip the throttle body as well as 1 of the only people to get a twin throttle body to work right . Best thing to do is pull your new 1 apart and have a good look at it and have a bit of a play. |
25-03-2008, 06:53 PM | #39 | ||
windsor user
the ECU switch point is 3800rpm
25-03-2008, 07:11 PM | #40 | ||
yeah i know the switch point is 3800rpm, its 4mm to get the butterfies to open 100% just did it then with the split BBM i have so for anyone going to do it there you go, i might try it see how it goes tommorow, i believe it could possibly be a minor restriction at WOT looking at it now....
25-03-2008, 07:14 PM | #41 | |||
25-03-2008, 08:28 PM | #42 | |||||
RIP...
The cam opens the inlet and exhaust valves. Rick.
25-03-2008, 09:26 PM | #43 | |||
let us know how it goes mate,if it don't work atleast its easy to put it back the way it was.
26-03-2008, 07:03 PM | #44 | ||
well had a closer look today, i reckon it could be a restriction at high RPM, as the air circles through the top of the BBM it enters the valve chambers on a down wards angle, im trying to draw a graph of it.
26-03-2008, 07:23 PM | #45 | ||
well heres the idea of what im talking about, i thought the air entered from the right but it enters from the left, i think the straight butterfly would be better, ive done it to my car will take it for a spin later see if theres any improvements by straightening the butterfly. you never know?
26-03-2008, 08:53 PM | #46 | ||
don't forget air is still being sucked through the long runners too.
30-03-2008, 11:52 AM | #47 | ||
I have done the samething to open the butterfly valves fully.
I just bent up the metal tab on the BBM actuator with a pair of long nose pliers. Gets about 5-10 degrees further travel so the butterfly valves should be completely open. Noticed a difference when above 3800rpm. When engine is off the BBM is switched at short runners(butterfly valves are open). When car is started there is vacuum present which holds BBM at long runners with butterfly valves closed. As engine revs past 3800rpm the vacuum is cut by the ecu thus open the butterfly valves.
EL monty pod filter, heat shield extractors, zorst, high flow cat Last edited by EL__Monty; 30-03-2008 at 12:09 PM. |
04-04-2008, 06:35 PM | #48 | ||
Smile
Ive taken a long hard look at this manifold since.I think straightenning the butterfly will restrict flow.I think the angled butterfly is conducive to flow. I smell inconsistancy here..
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again Last edited by Stav; 04-04-2008 at 06:50 PM. |
05-04-2008, 08:22 PM | #49 | ||
well i can't say ive noticed any improvements, its a hard one, i had a look of the insides of the Ba bbm today, that manifold is alot better than Au, the valve/chaambers butterflies are all bigger by 3-4mm but its a thirstier motor the ba. There would be gains to be had in your Au thou would have to be punching out some good numbers.. so mayb JMM is right at a certain point it is a restiction, a point im far from just like many others!
05-04-2008, 08:27 PM | #50 | ||
im presuming the BA one bolts on..?? or is it SLIGHTLY different like the exhaust side ??
05-04-2008, 08:41 PM | #51 | ||
windsor user
just give the manifold ports a nice clean up and match-port the lower to the head, and match port the upper to lower if possible...
you'll gain a lot more by doing this and smoothing out the flow than you will mucking about with the butterflies.......... ford didnt just slap them in there and say, "they'll do, the angle doesnt matter" im sure they would have had a huge amount of testing to get the angles right |
26-05-2008, 08:30 PM | #52 | ||
Smile
I removed the upper intake today. The butterflies are definately at an angle.I also discovered that my throttle body gasket was blocking flow so I recut it. I also proceeded to bend the metal stopper to straighten the butterfly angle into the manifold. I can honestly say that my car feels alot slower. Its not gonna beat its pb after this modification.I have broken my own rules..if its going great..dont touch it.!! I hope I can give it back some punch..
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
26-05-2008, 08:33 PM | #53 | ||
Smile
Might have to put a restrictive gasket back in
26-05-2008, 08:55 PM | #54 | |||
Sales Representative
Project InfernoSR - Back Burner Project FeralTerra - No longer Project Fairmont Prodigy - Sold Thanks go to: MY WIFE! Bathurst Brakepro Undacar eBay!! |
26-05-2008, 10:09 PM | #55 | ||
Smile
The car would lunge forward like a monster before this mod. I am going to fiddle with it tommorow and see if I can find a happy medium.
27-05-2008, 10:43 PM | #56 | ||
Smile
Fiddle I did!! The datalogger registered a leanout towards 14 under wot. The bbm tip in did nothing when the butterflies were set to fully open. I came home in the afternoon and found my rubber hose.Found a tiny airleak at the throttle body . The car feels stronger down low but not quite as good as before. I have learnt a valuable lesson here. There is more power to be had with more air going in..(even if it was a leak!!)However the sacrifice in bottom end acceleration is not worth the trouble on a daily driven car. I couldnt even overtake a slk 230 mercedestoday.I normally eat them for breakfast..Loss of low down power is too big a compromise that I won't be sacrificing again if I can get the wagon back to its line munching torque.
I tuned for the air leak and can honestly say that the car gained more power at the expense of the low to midrange punch which dominates street overtaking acceleration.
27-10-2016, 12:25 PM | #57 | ||
There must be something in the butterflies angle as the BA has bigger butterflies but still runs the angle
07-11-2016, 02:00 AM | #58 | |||
......Car Crazy......
FG-X XR6 SPRINT Victory Gold - 025/500 VIC-XR6TS AUIII XR6 ST Blueprint - 1 of 125 VIC-XR6ST EBII S XR6 Everglade Garaged VIC-SXR6EB WANTED - BF MK2.5 XR6 Seduce - PM me RIP SHYXR
