Anyone know someone who can make a custom subwoofer box to hold 2 12" subbys and an amp?
Aspiring mr efxr
i did mine. y not DIY? bout $70 for mine including checker plate n carpet....
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
alright did you just use mdf?
Aspiring mr efxr
yeah 18mm from bunnings and got them to cut the majority of it. $14 labour i think it was... pva glued all joins then used 22mm self tapping screws.
had to cut angled ends myself
alright thankx ill get some wood tomorow and start contruction it
What happened to the box that you had?
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
Eastside Installs - 0402855801
Sundeep |
Fish if you want it done proffesionaly give Eastside Installs a call. Doug runs it and he is the one who installed my system, he knows his stuff and doesn't charge an arm and a leg. I'll show you my system on tuesday.
likes falcon's
DVE- 0413527096 ask for Daniel
sample of his work http://www.fordforums.com.au/showthread.php?t=51644
www.carhubsales.com.au |
BA Mk2 XR6 Turbo
have you got the manuals for the subs?
have a good look in there. you will find tested box sizes & shapes (well kicker supplies diagrams in manuals) secondly a fair bit of trial & error is needed once you have the rough box size & shape. as your ears & listening style will be different to everyone elses. ohh and dont foreget to rip up on old pillow. (you want the insides) spread evenly between the 2 boxes. you want between 40% & 60% of the sub box filled with pillow insides (cant member the stuffings name). ohh and make sure you put a mass devider between the subs. itll sound better. bradman |
Aspiring mr efxr
i didnt bother with the pillow business. wot is it actually meant to do?
#12 | ||
BA Mk2 XR6 Turbo
it adds depth to the box.
it is supposed to make a physical 100L box a theoritical 125-150L box. it is supposed to give better bass. i cant say wether or not it makes a difference as ive never run a sub without it in there. its a recommended thing to do wid kickers. and im pretty sure JL says you should do it to. bradman |
