31-08-2006, 03:24 PM | #61 | |||
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
31-08-2006, 03:35 PM | #62 | |||
Adapt or perish...
That was meant for futura01.
Carless
31-08-2006, 03:48 PM | #63 | ||
horsepower
Nah thats cool guys, i understood well i recieved the official au cam specs for the stage2 camtech cam and they are almost identical to the high torque cam that baboon has ordered.
The cam specs for both cam's should prove well considering that they have a little more lift then the xr6 cam on intake and little bit more duration. I actually think that i might be getting the same cam as baboon soon. I believe these cams might be more suited to std heads ? |
31-08-2006, 03:50 PM | #64 | ||
Adapt or perish...
I'd say so, mine is like a XR6 cam, but I do like the sound of the one jonbays mentioned a little while back in this thread. How that would work in a stock head would be of interest.
Carless
31-08-2006, 03:54 PM | #65 | ||
horsepower
Yeah well i think a little bit of playing with the cam through a vernier gear might prove the diffrence ;-)
31-08-2006, 06:30 PM | #66 | |||
Boost Addict
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
31-08-2006, 06:37 PM | #67 | |||
TL40 Wagon?
Just look at the VCT which basicly runs retaded and advances 10 degrees from 1000-3800rpm to give better mid range it only pulls up the XR6 engine from 164 to 172fwkw. Of course a wider powerband is more impressive on the track and road than the dyno too. |
03-09-2006, 01:23 PM | #68 | ||
TL40 Wagon?
Well I just swapped out the Crow 2232549 cam I had for a Jim Mock Motorsport Dev5 and its just so much better at idle and below 2500rpm its not funny. Even with a Unichip to tune the idle the Crow was pretty ordinary with an Automatic. Now without even retuning the Unichip the idle is great and cruise at 2000-2500rpm part throttle is much better. The JMM cam strategy is just way better for any street application or auto.
03-09-2006, 04:02 PM | #69 | ||
Boost Addict
thats where u have to decide if u want street application or outright power and then make the selection!
btw u can alter the ideling characteristics by porting the heads as well. we did a lot of testing in that area and ended up with rather large exhaust port and slight increased intake ports. not to mention the improvements in performance
03-09-2006, 09:29 PM | #70 | |||
TL40 Wagon?
04-09-2006, 12:45 AM | #71 | |||
Boost Addict
