Smile
Guys I know that the AU transmission has no dipstick but I dont believe the filter had to be changed all the time. Id like to get a plug welded into the pan so I can just drain it and refill it .I cant be bothered to drop the pan each time as it is a pain in the butt.
Has anyone done this?
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
I think it's B&M that do a trans plug kit, but you will have to remove the pan to get it fitted
Smile
Thats fine.I was thinking I may be able to weld a nut inside and have a bolt with washer outside.Undo the bolt ,refill the plug and voila..dont have to muck around in future with removing the pan every time.
AUII Fairmont Ghia
im not thinking too well 2 nite but couldnt you do it at the oil cooler line
#5 | |||
Smile
AUII Fairmont Ghia
you only get about 1/2 by dropping pan rest is in the convertor
Then how do you get rid of it properly then? Is it a pain to take the convertor out?
uh yeah...you have to take the transmission off to get the convertor out
AUII Fairmont Ghia
get a transmission flush any good trans place can do it
![]() Join Date: Dec 2004
Use a normal falcon sump plug and fibre washer which is 1/2" UNF thread ,drill hole and weld a 1/2" UNF nut inside the pan.Done plenty this way
Back on the road
A drain plug in the auto pan would certainly be handy...
Dropping the pan is a PITA
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#12 | ||
Miami Pilot
![]() Join Date: Jan 2005
Couldn't you use a pump to drain it from the filler hole? Either hand or drill operated would work, maybe.....?
#13 | ||
Back on the road
I've only ever been able to get a litre or two out using a handpump. The insides of the transmission stop the tube/hose from getting anywhere near the bottomof the pan.
