Hey au fans
I have an issue with my s3 xr6 locking. I can't actually get into the car without a great deal of trouble. Neither the key fob or the actual key unlock the car. When I press the unlock button, the door lock will cycle, come up, then it goes back down and it won't actually unlock. I put the key in and try to unlock it that way and the same thing happens. Is this a shagged actuator motor? I replaced the actuator cog in my forte but that caused a different issue which would allow the car to be unlocked by pulling on the rear door handles. I can't actually get into my xr6. Not without pulling the door handle and interrupting the unlocking/locking cycle that it's in. And I learned the hard way that doing this displaces the inside door handle cable leaving the door unable to be shut properly. Although it does actually let me get into the car. This is obviously not ideal, as I can't drive it with a door that won't stay shut! ![]() |
It does sound like an actuator although it's the reverse of what normally happens when they fail as they usually don't lock.
![]() Join Date: Oct 2006
Could be a bent snipper rod - the push rod that goes from the button on top of the driver's door sill to the actuator or the button on top of the snipper rod not sitting correctly in it's sill surround so that it can't be pushed all the way up by the actuator so returns immediately to the lock position. These fault typically cause the locks to continually recycle. Same deal if the plastic button on top of the rod is broken, has lost its thread or is screwed on too far or too little.
regards Blue Last edited by aussiblue; 28-09-2019 at 01:04 PM. |
I had this problem and the solution aussiblue mentioned did the trick. I was changing over locks at the time.
I took the card off today and snipper rod looked ok but I could be wrong.
I replaced the actuator motor, and the cog inside was in good condition, so I now know it's definitely not those two things. When I press unlock with the remote the lock jumps up but then returns to the locked position. It is luck as to whether the door will unlock or not. If I lift the handle and then go through a process of unlocking twice (all doors), locking, and then unlocking again it seems to open. That's the only idea I have. If it is indeed the snipper rod- I'm just a dummy and don't know it's bent or not-, are they easy to source? Last edited by TeamSAXON; 28-09-2019 at 08:01 PM. |
#6 | |||
regards Blue |
I'll have another look at it when I can get the card off again. The door opens itself slightly when it does actually decide to unlock properly, I don't know if that's another sign of what is going wrong?
#8 | |||
regards Blue |
#10 | ||||
Don't know if it ever was in an accident. Had it since Jan with no issues. Door seal rubber isn't great the rear rubber often falls out. The rear drivers side door is maybe 1 mm out when closed because of that rubber. May just move the latch a little if I can get it off. Quote:
Just the electrics or the whole door? |
Just electrical
#12 | ||
Right I'll try that.
Someone asked me if the dash button operates properly. I tried the dash button to lock the car today while inside and it locked and unlocked like a door was left open. I tried a couple of times and locked the car. The drivers door handle was hard to pull when the car was locked. I can video what's going on if that makes it easier to diagnose. I'm pretty close to taking it to a locksmith or my mechanic! |
#13 | ||
Try opening the drivers door and using a screwdriver or similar to flick the latch in the door lock then see how hard it is to unlock. will help eliminate potential alignment issue
AUII XR6, BF Built Turbo engine, SOON TO BE FG ENGINE... FG head and inlet manifold. GTX3582R, KPM 1500cc injectors, Process west rail and internal pump surge, Tuned by CMS, 370rwkw. 6 speed manual, NPC twin plate clutch, mal wood under dash hydraulic clutch. 4 pot brembos and territory rears |
#14 | |||
Ok this gives me something to go on, it is easy to unlock with the inside handle when the latch has been flicked as you described. So guessing I need to undo and move the pillar latch? |
#15 | ||
Took out the snipper rod, not sure if it is normal or bent. Photos of it here since my picture links keep breaking: http://www.fordforums.com.au/photos/...ppuser=2393509
