20-05-2018, 04:44 PM | #1 | ||
I have recently purchased a 95 ef fairmont but it has no reverse lamps,i have checked the bulbs and fuse but to no avail,where do i go from here?.
20-05-2018, 04:53 PM | #2 | ||
Check the relay or the switch on the transmission. There are probably more scientific places to check but if you start small there's a high chance that it's a cheap component.
23-05-2018, 07:35 AM | #3 | ||
The one and only
Change the inhibitor switch on the transmission.
Like most auto's, this controls reverse lamps as well as the neutral/park start.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
29-05-2018, 09:06 PM | #4 | ||
changed the inhibitor switch but no differance.
30-05-2018, 07:19 AM | #5 | ||
The one and only
With the ignition on, check you are getting power at the switch
30-05-2018, 07:23 PM | #6 | ||
Sorry if i sound like i have limited knowledge on what to do but do i turn the ignition on until the dash lights up,do i put the gear selector in reverse or just leave it in park and which wire(colour) do i prod at the inhibitor,i have pulled the tail light out and tested at the bulb but no power getting to that at all.
31-05-2018, 07:25 AM | #7 | ||
The one and only
Leave in park.
Turn key to "on" Climb under car and make sure there is power at switch.
10-06-2018, 07:52 AM | #8 | ||
Finally got a chance to look at the switch,tested it and there is no power at all getting to it,where to from here.
10-06-2018, 09:40 AM | #9 | ||
Also there is power at the fuse that is in the fuse box on the right hand lower side of the steering wheel.
30-08-2018, 07:45 AM | #10 | ||
The one and only
How'd you go mate, work it out?
08-03-2019, 01:16 PM | #11 | ||
14-03-2019, 08:11 AM | #12 | ||
The one and only
