#2 | |||
#neuteredlyfe
![]() ![]() Join Date: Apr 2012
Slight problem with that - it's a ute (charcoal XR6 interior, not leather).
Does the overhead console/sunglass holder thing normally just "float" on the headlining? Wondered if it could have been from that. |
#4 | |||
#neuteredlyfe
![]() For the last three days I have pulled out the entire interior in my XR6 ute, cleaned it bit by bit and put it all back in and did not come across one of those clips. |
Three days? I'm still going; this one is filthy.
I have never seen one like that in an AU
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
I was just working on my wife's Mazda 6 & came across almost the exact same clip. There were 3 of them used to retain the headlining across the rear windscreen area.
Found another one, opposite side of the car, under the carpet. Interesting.
Next upgraded Mk1 Leopard
They are similar to ones I've seen in the engine bay. carpet clips?
UK
Neither were pushed home, so I did wonder if they were discarded from an assembly used on other models and differently employed in the Falcon. The carpet definitely hasn't been up since January 2006, can't say before then.
