07-05-2012, 10:44 PM | #1 | ||
i just got a au xr8 and near the auto shifter it has a adaptive shift sticker what is it and how do i use it
cheers
TE50 T2 AU2 GHIA |
07-05-2012, 11:02 PM | #2 | ||
It learns your driving style and will shift accordingly. Google search will explain in depth
07-05-2012, 11:02 PM | #3 | ||
The adaptive shift feature is controlled by the EEC which continuously monitors the the drivers throttle inputs to determine your driving style. It then modifies the shift feel to suit the driving style.
It can be manually programmed to select economy or performance modes. To manually select the desired mode :- 1) stop the car, apply hadbrake and turn ignition off 2) Apply foot brake and move the shifter to : "1" for Performance "2" for economy "3" for adaptive. 3) Turn the ignition to (II) and wait for the airbag warning light to go off. 4) Move the selector to R. The ECON light will flash three times to indicate a sucessful mode change. 5) Return the selector to Park and start the engine. observ the econ light. one flash indicates performance continous illumination indicates Economy no light indicates adaptive. cheers
XR8 II ute auto Silouette XR8 II ute manual Venom 66 Mustang Convertible 56 F100 |
07-05-2012, 11:47 PM | #4 | ||
It's pointless basically and isn't worth a crumpet
08-05-2012, 12:58 AM | #5 | |||
TE50 T2 AU2 GHIA |
08-05-2012, 08:36 AM | #6 | |||
08-05-2012, 10:06 PM | #7 | |||
Stay Classy ™
ESS, well, that's a little better but the novelty wears off after a while. |
09-05-2012, 09:08 PM | #8 | ||
I have no Econ light so I'm not shore
TE50 T2 AU2 GHIA |
09-05-2012, 09:33 PM | #9 | |||
Your XR has the Adaptive shift strategy by default. However other modes can be activated as nassi explained. |
09-05-2012, 11:04 PM | #10 | ||
Thanks mate
TE50 T2 AU2 GHIA |
29-01-2018, 09:26 PM | #11 | ||
Is it only on xr models or can it be applied on all au 2 and 3 s
Btw i have a au2 i6 xl ute |
29-01-2018, 10:51 PM | #12 | ||
2009 xr turbo,2004 fiesta
Try the instructions on the 3rd post and see.
Im curious now too,i had a bit of a play with it before on my xr8s. |
