#31 | ||
Oops, I slipped....
It's not the best picture, but it should show you what I mean about the front of E-Series not being able to have a spigot on the adapter.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
#32 | ||
AKA MYTE8
Why can't you use these on the front
It has the raised bit in the midle for the wheel to sit on, or does it need to be longer ?
#33 | ||
Oops, I slipped....
Where will the spigot go on the adaptor? The front hubs on E-series have long (sit out to the sides of the car) spigots, the backs are fine.
If the adapters were wide enough to fit over the standard hub and still have a spigot machined into them, they would be fine, but as someone said earlier, the wheels will be sticking out and rubbing on the guards.
#34 | ||
whats a spigot :O
[COLOR=Navy][FONT=Arial Black]_________________________________________ [CENTER]88 EA Fairmont Ghia - Super lows (all corners) - Shortened Shocks - Custom CAI - Clear Indicators - EF XR8 LSD - EL XR 6 Head - Jim Mock XR6 cam re-ground - BF XR6 17's - Advance Extractor's - Redback 2.5" sports exhaust - |
#35 | ||
rofl copter
tornado, u can get aftermarket wheels, that have the e-series offset..
GQ patrol.
.... thats all |
#36 | |||
Windsor Man!
What do you mean by spigots?
Wife's car - BA XT Wagon - Lowm shiney wheels, dark tint, no bottom half of front bar, faded paint :/ My Car - 93 Diesel Lux - not as fast but more reliable than her falcon! |
#37 | |||
Windsor Man!
#38 | ||
Could you just fit the AU front & rear ends so that the E series could accept the AU wheels?
I could not see the rear being a problem at all but I don't know whether you could fit the AU's front suspension arms & spindles up. |
#39 | |||
E-series and AU-on have reversed balljoints, so it's not as easy as swapping over the uprights. The top arms will bolt up to the E-series car so the top isn't a problem but the lower AU A-arm needs matching mounts and thus the alloy crossmembers rather than the single arm and trailing link and the pressed steel K-frame. Doable but not worth it just for wheels IMHO.
#40 | |||
windsor user
would need to get an engineers certificate for the conversion, though it wouldnt be hard to do it right... |
#41 | |||
Maybe when my EB engine finally cries enough I will buy a wrecked AU for the engine & give the suspension a try too. |
