11-12-2009, 08:48 AM | #1 | ||
my car is surging when i accelerate up hills, its not bad but you can feel it pull back and then go again. injectors? never had them cleaned.
thoughts? P.S it does it with the A/C on or off. car has new plugs/leads and had a fault code check that was clear. throttle body has been cleaned. |
11-12-2009, 09:25 AM | #2 | ||
i had a same problem turned out to be my leads, when i put my foot down it would cough and splatter, also make sure you dont have water in the fuel, that also could cause the surging,
fuel filter fuel pump
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
11-12-2009, 10:27 AM | #3 | ||
Flairs - Truckers Delight
invest your money in LPG instead?
11-12-2009, 11:23 AM | #4 | ||
Check the earthing between the battery and the engine block and the chassis. My car was doing similar and it was due to a stuffed earthing lead from the battery to the block. It had a voltage drop of 0.5volts between the battery and the block. A voltage drop of this magnitude can affect the signal from the oxy sensor and which in turn affects what the ecu does to enhance performance under load.
11-12-2009, 03:48 PM | #5 | |||
11-12-2009, 08:01 PM | #6 | ||
Just slidin'
Id say fuel filter. Give it a heap pf curry around a corner (like your trying to get sideways, but dont) with under half a tank, if it surges then, its your fuel filter.
MD Mondeo - For the family
NP Pajero - For the adventure |
11-12-2009, 08:55 PM | #7 | |||
it would only be a matter of time, they all come back to LPG in the end, it's just too good to go away from. Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
15-12-2009, 01:29 PM | #8 | ||
First Ford Owner
I had that issue about 8 months back and ended up having to replace my Ignition Coil!!!
If you dont like the heat, then get out of the bloody fire |
15-12-2009, 06:17 PM | #9 | ||
I'm having the same problem. It's very minor and if someone jumped in the car and took it for a spin they wouldn't notice it but driving it everyday and getting used to the car you can feel it.
I haven't found the solution. Only thing I have done to date is set the TPS. As the guys have said it would be a number of things but over the break I am going to do the following(some to rectify other issues im having) and hope I can kill two birds with one stone. - Run a fat earth cable from block to battery - change fuel filter - run a bottle of injector cleaner - new msd coils & leads Will let you know how I go if you haven't worked it out in a few weeks time.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
15-12-2009, 06:52 PM | #10 | ||
[ 5L ]
i had same sort of problem, found a cracked spark plug replaced that. car was good for a day or 2, replaced my MSD leads with my standard ones same problem. ended up being corrosion in my MSD coil packs where one of the spark plug leads goes. cleaned it out with a light sand and some crc spray.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
03-01-2010, 11:44 PM | #11 | |||
IR84RD
3rd generation Ford man 01 AUII XR8 220kw White |
04-01-2010, 07:42 AM | #12 | ||
Just slidin'
No probs. Mine actually was an original from the factory (110000km on it) and there was so much crap in the bottom of the fuel tank we replaced the pump as well, with the Walbro unit.
05-01-2010, 06:55 PM | #13 | |||
Losing my patients with unfinished threads Did the ideas people helped you with work or not! |
05-01-2010, 07:18 PM | #14 | |||
Back to Le Frenchy
Coil pack(s), fuel filter, fuel pump sock....
Is it for a 6 or 8?
05-01-2010, 11:42 PM | #15 | ||
where is, and how do you change the fuel filter?
05-01-2010, 11:50 PM | #16 | ||
Had the same in my AU (many years ago) and it was a buggered lead, even though it was only a couple of months old.
06-01-2010, 02:54 PM | #17 | ||
Just slidin'
Under the rear of the car, get in underneath the rear passengers door area. Need 2 spanners and a hose. Undo the two nuts to seperate them, then after you get covered in fuel, hose yourself.
07-01-2010, 12:36 AM | #18 | |||
Miami Pilot
The fuel lines may have the quickfit connectors on one side of the filter too - just go to supercheap or repco and buy a set of quickfit removal tools (about $15 from memory).
07-01-2010, 06:38 AM | #19 | ||
Just slidin'
Good idea JC, sure beats getting covered in fuel and smelling like ethanol for a week.
30-07-2010, 12:18 PM | #20 | ||
Thread Mine alert.
OP, I was wondering if you resolved your issue here? I have changed fuel filter, run injector cleaner, fitted msd coils and leads, new o2 sensors, fitted 4 guage cable from front crossmember>negative terminal and replaced tiny earth from alternator>negative terminal with 8 guage. Problem remains.
30-07-2010, 05:23 PM | #21 | ||
Stay Classy ™
Had a look at the sock for the fuel pump, Whoosha posted a guide about how to replace it since his son's SR was having issues.
30-07-2010, 09:20 PM | #22 | ||
Right out sideways
my au xr8 is doing exactly as monty describes...... surges like a rev limiter when under 1/4 tank. Fuel filter is only 6 months old, but will change it again and hopefully it will sort it out. And thanks for the tip also JC, will give that a go for sure
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
09-10-2011, 06:30 AM | #23 | ||
I have a 03 ford ba futura an sometimes when im stopped at lights the revs drop down then back to normal put a new fuel filter in its still doing same prob took it in to fords an its coming up with a fault code an they theres nothing wrong with my cam timing, coils, fuel pump,etc are good an they say it might be exhaust emissions so i was get if i was to get my fuel injectors cleand an having a look the catalytic converter to see if its clogged or maybe blogged that get rid of my problem ....?????
09-10-2011, 06:35 AM | #24 | ||
and its also surging when when i accelerate from lights to.
09-10-2011, 06:52 AM | #25 | ||
meh.
Welcome to the forums!!...
Here's a thread that will be helpful for you.... http://fordforums.com.au/showthread....ight=idle+drop Also, usually the correct area to post in is "B-Series.com.au" and for questions like these, in "B-Series Technical".... Cheers.... -xrghiawagon
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
15-06-2015, 06:21 PM | #26 | ||
Question has anyone sorted this problem ?? as I am going nuts over a au xr6 with the same gremlins as everyone has described, any advice would be great.
15-06-2015, 07:56 PM | #27 | |||
Au Falcon = Mr Reliable
cheer's, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) Last edited by Maka; 15-06-2015 at 08:14 PM. |
19-11-2016, 09:25 PM | #28 | ||
Papa Smurf
we are having trouble with my wifes 2007 Ford Territory, it has had this intermittent surge / engine lose of power. Everyone has had the same or similar fault but a "ZILLION" different ideas to fix it!!!.Replaced coils and spark plugs, fuel filter, fitted extra lead from battery to engine, swapped fuel pump relay and seemed OK, maybe for a while. But then it seemed to have same sort of fault, or maybe a slightly different?. Then I fitted extractors and high flow cat exhaust ,,,that upset the computer because ever since computer light comes on saying lean exhaust!!!.Fitted new O2 senser, cam sensers,Then I changed TPS and accelerator pedal (fly by wire), again went OK for a week or 2... Just in last couple of weeks the car cut out, stopped completely, re-started a few minites later and I got a chance to drive it!... it was surging like blocked fuel filter or lack of pressure. Replaced the fuel pump and fuel filter (filter seemed fine but change it anyway). Car has gone great for 2 weeks and done a couple of hundred k's. BUT... wife said it played up a little bit again today... really had enough of the car but maybe,,, fuel pressure regulator ???????
19-11-2016, 10:04 PM | #29 | ||
Maybe leads if not done already
