Old 20-04-2015, 06:51 PM   #1
falcon_bandit
Default Used Diffs - Which one is which?
Looking round for XR6 HP 3:45 diffs, and i can tell if its IRS or Live Axle. Any particular things to spot?
Oh and does an AU XR6 live axle diff bolt straight into an AU futura or are the mounting points different?
falcon_bandit is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2015, 07:34 PM   #2
falcon_bandit
Default Re: Used Diffs - Which one is which?
"i cant tell if its IRS or live axle"
Old 20-04-2015, 07:52 PM   #3
falcon_bandit
http://www.fordforums.com.au/showthread.php?t=11243653
Old 23-04-2015, 07:12 AM   #4
falcon_bandit
anyone know how to tell from a pic which is IRS and which is liveaxle?
Old 23-04-2015, 08:12 AM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Well if it's an XR6 HP it'll be non-irs, won't it? And won't an IRS diff have CV joints that bolt up to the side of the diff centre? And won't a live axle diff have the axle joined to the diff, ie a whole stub-to-stub unit? From memory they look nothing at all alike.
Old 23-04-2015, 01:05 PM   #6
falcon_bandit
yeah looking for a HP diff, just i literally have no idea how to tell them apart. I dont even know what a CV joint is. Can send msgs to sellers on ebay and gumtree to ask, but thought if there was an obvious way to tell difference it would save some time
Old 23-04-2015, 04:45 PM   #7
Jarry
Going with the X-Flow
Jarry's Avatar
Hi Mate,
It's really simple. You'll kick yourself when you see the pics...
IRS Sedan Diff
UTE Diff
Live Axle Sedan Diff
You're after a live axle sedan diff.
The XR6 HP came with a 3.45:1 ratio. And in AU1 LSD was standard. In AU2/3 LSD was optional.
The sedan live axle has the watts linkage (the big chrome pin sticking out of the diff hat), upper and lower trailing arm mounts and coil spring saddles.
The ute/wagon doesn't come with sway bar or watts linkage and just has saddle mounts for the hotchkiss leaf sprung rear end set-up.
The XR6 HP diff shown in the picture above is non-LSD because the sticker is white. If you want an LSD, get one with a yellow sticker AND the "high performance diff" tag bolted to the diff hat. Good luck and happy shopping!!!
P.S. AU1 will fit AU2/3 and vice versa. Just gotta use your existing discs and calipers. Handbrake shoes are the same. Handbrake cables are slightly different, but again just use your own.
Last edited by Jarry; 23-04-2015 at 05:00 PM. Reason: Buggered up on the sticker colour
Jarry is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2015, 04:50 PM   #8
Jarry
Jarry's Avatar
FAIL on the call about the yellow sticker. I've clearly got that wrong!!
Here is one on ebay with LSD and a white sticker... Sorry about that!!
http://www.ebay.com.au/itm/LSD-diff-...item43d9c54f76
Looks as if this particular diff has a leaking pinion shaft seal too BTW.
Old 23-04-2015, 07:43 PM   #9
falcon_bandit
legends, thank you.
