02-01-2015, 04:04 PM | #1 | ||
Innit
Went away for a couple of weeks over Chrissy, come home to find a hole in the floor of my Territory!
Clearly the work of a rodent, it's also pecked away at the foam under the rear seats. Need some ideas to kill the little bastards, last night I set a trap but no joy. Anyone know what a carpet retrim is worth?
FG XR6T SZ Territory TDCi |
02-01-2015, 04:42 PM | #2 | ||
ratsack.
http://www.ratsak.com.au/ Last edited by mik; 02-01-2015 at 04:44 PM. Reason: add |
02-01-2015, 05:06 PM | #4 | ||
Giddy up.
If you want to put something in there that isn’t as toxic/harmful if you have kids etc, put a bit of soda or something, like schweppes in an open container, make sure it’s fresh though with bubbles, as mice/rat’s can not burp and the gas ends up killing them, when it’s flat just replace with fresh bubbles.
02-01-2015, 05:17 PM | #5 | ||
FPV GTR
They get in through the aircon drain I believe. Pretty common problems for Terris unfortunately. Pull your glovebox out and you will likely find a chewed pipe and the buggers point of entry. Remove any water bottles you might have left in the car or food scraps. Also dont bait the rodent either as your likely have it die somewhere in the car, stinking it out and noway of finding where it is.
- FPV GT RSpec - - Chill SZ Territory Titanium -
The Family Bus - Veridian Green PJ Ranger XLT - The Work Truck |
02-01-2015, 05:21 PM | #6 | ||
Get "The Big Cheese Mouse trap station" from bunnings etc. I have had 100% success rate and the trap is all contained. Catch and open up trap station and throw mouse away, reuse if multiple mice. Put the station in the car when not in use overnight maybe.
Good luck. |
02-01-2015, 06:40 PM | #7 | |||
Innit
Insurance have said they will cover it thankfully. Just hope they haven't done more damage that can't be seen.
02-01-2015, 06:40 PM | #8 | ||
FG XR6 Tray back
Yeh i'm not a fan of putting baits out to get them, one died in the wifes Barina air vent, spewed all the way to work, and all the way home. The only time i would put baits out is if you put them away from the vehicle. A trap in/or around the vehicle sounds like the go. Try pumpkin seeds in the trap. Good luck.
02-01-2015, 07:04 PM | #9 | ||
Had this happen when I lived on a farm. Mice moved in to the car... I set one of those traps where they can get in but can't get out with peanut butter left in it. Got the whole mice family in one night.
02-01-2015, 07:48 PM | #10 | ||
I live on a farm too. My rat trap is a bucket 2/3rds filled with water and a layer of sunflower seeds floating on the water. The bucket is placed where the rats can walk along the rails of the shed and jump in to eat the seeds. I empty the bucket every couple of days and usually catch two or three each time.
02-01-2015, 08:53 PM | #12 | |||
____________________ 2019 LDV G10 2009 Mitsubishi Express-GONE 2011 Honda Jazz ____________________ |
02-01-2015, 09:35 PM | #13 | ||
02-01-2015, 10:27 PM | #14 | ||
Set mice traps in the areas the rodent has frequented. Even if you just go nuts at night & remove them in the morning.
Don't do anything to block it's path, ie; don't repair any damage just yet, just let mousey think it's life as normal. I find peanut butter is the best. It emits an odour for a while & it is hard for the mice to remove from the trap without setting it off. (I've seen that many a time) The mouse will definitely return to it's entry point during the day (deep in the dash I'd say) or if you're using the vehicle. It might have even escaped already if there's not enough food. At this point if you have already used disinfectant, I'd go nuts during the daylight hours. Open all doors, remove the rear seat, glove box & anything else that's easily removed & refitted at the end of the day. Then whilst it's stripped out, buy a few cans of Glen 20 & fumigate the car, especially the dash. Go nuts with the stuff. If mousy cannot breath it will escape even if you are standing right there. |
03-01-2015, 11:27 AM | #16 | ||
I bought to kittens to be barn cats. Kept them inside mostly for six months and waited til they became quite big. I then put them in the barn at night. After a week I went there one morning to let them out and found one had been literally torn to shreds and the other was hiding behind a feed bin and scared spitless.
If I'm not home in time to feed the stock before dark then I don't feed anyone til morning. Everyone has a predator and I'm not meeting whatever preys on what tore that cat apart. |
03-01-2015, 11:42 AM | #17 | ||
When we had a mice plague the cats ate half of the mice.the chickens had the rest lol
03-01-2015, 07:39 PM | #18 | ||
They eat the insulation off the wiring. The PVC tastes sweet to them. This is a very common problem not only here but in the UK as well. My cousin had them under the bonnet of his Mini.
The manufacturers need to put cyanide into the PVC mix. That would fettle them. |
