Tippy-tronic Free Zone
Hi folks,
Just acquired a Type 5 4spd to replace the external linkage one on my Capri V6. But....Need a few bits to make it all complete Anyone know where I can find these? Part Number 72GG-7227-AA Description Compression spring on manual gearshift lever, between nylon ball and upper cone + lock cap Part Number 72GG-155520-CA Description Reversing light switch Part Number ????? Description Boot covering shifter shaft entry into gearbox extension. Not sure if same as item below, I don't have the parts diagram, only a parts listing. Part Number 72GG-7277-NA Description Boot - gear change lever (? possible part number for the gearshift into the box, or even the floor hole cover) Thanks in advance......... |
Hi Allan,
The reverse light switch can be sourced from ebay or Burtons: http://www.burtonpower.com/tuning-gu...e-gbt9545.html You can buy new and used gearshift assemblies (depending on the thread size needed) from Motomobil in Germany, who would also have the reverse switch: http://www.motomobil.com/produkte,32...egory_id=12&q= Not sure if anyone in Oz can source these? Cheers Jamie |
You may need to be creative with the floor hole boot, as the rubber boot for the type 5 was round like the 4cyl ones. Maybe fit a boot from the external linkage box with the metal surround to clamp it down?
Cosworthfreak - thanks for the reply.
I'm aware of Motomobil (EUR100+ for a gearstick) and Burtons for the reverse switch. And the gearstick boot-over-cone I need looks awfully like a Type 9 style. Was hoping to find things a bit more local .....Ha ha ha, yeah right..... |
Try an Escort boot...,may be a little small.
I recently picked up a type 5 from a new club member who recently arrived with a container load of parts from the UK....As you can image, he's a popular fellow at the meetings. PM me and I'll forward you his mobile number. Pretty sure he can help. |
Well, after some digging around the web and my boxes of junk.....
1. I found the steering wheel hub spring will do for the gearstick compression spring. One problem solved. 2. The reversing light switch I bought from Burtions and was assured was correct....ain't. A 3/4" x 2.5tpi is not equal to a 14mm x1.5tpi (nil response to mismatch issue I raised with Burtons). Some other web sites have them listed - Motomobil out of stock (no supplier), another queried with no response, and another site I ordered successfully was cancelled with 'the website is built wrong, no supplier'. Marvellous. Or..I'll try soldering some pins onto the back of my ground-away old switch. Or..I'll make a threaded sleeve to pad out the Burtons-supplied Type 9 switch to fit the Type 5 box. 3. The boot into the geatrstick extension can be mostly covered by a 4 cyl gearstick boot. Might do at a pinch..... 4. The floor boot I can use a generic or a 4cyl as suggested, so no problem there. Some progress, other issues need more thought. p.s. Whooligan - PM sent |
