HI All
Where is the fuse for the factory aerial fuse? Fuse location , no. , would be great. Aerial stopped working today but can still hear the BEM "click" reversing the polarity for up and down. Want to rule out fuse issue first. Cheers Dazza |
Is the aerial motor still whirring?
Ok
Its not the fuse. It is not the aerial as this works fines. Checked it by unpluging and supplying 12V to extend then reverse polarity to retrack. Even tried another spare unit I have. Looks like it is a faulty BCM which operates the aerial. Unless I have overlooked something. Thought it may be the trigger wire from Radio but when ignition is turned off I believe this overides the radio trigger retracting the aerial. Any help would be welcomed. Cheers Dazza |
