01-09-2012, 01:22 PM | #1 | ||
wild xr8
Just bought an NL Fairlane and am going to swap all the leather, elec windows, woodgrain and chrome goodies into the xr and was wondering if anyone has put the climate control modules in? would i need to change heater box and all the dash assembly or is it as easy as pullin old standard one out and plugging new one in? would i need to change bcm or anything over to run the electric windows?
cheers burkie |
01-09-2012, 05:45 PM | #2 | ||
it will require the dash to come out, and swap a blend door motor into your heaterbox, take out the old cable operated one.
the sensor/thermostat module is different, behind the glovebox. and the dash loom is different too fitting the NL loom will also require a few more mods to work with the EL dash instruments, the plugs are different. if yopu can, use an EL Fairmont dash loom. im not sure if there's a tech document on the conversion here? it can take around 6 hours doing it the first time... there is a technical document on Fordmods for this.
Money Talks, but all i ever hear is it saying Goodbye!! |
01-09-2012, 07:11 PM | #3 | |||
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
01-09-2012, 07:11 PM | #4 | ||
you'd be popular too
I put a tech doc for fairmont to XR but does not include climate control, as my67xr said(same guy who helped me) fairmont loom plugs straight in for windows
98 EL XR8II Manual E303 cam, ported gt40p heads, 1.7 rockers, high flow cats, Au220 TB, 70mm Maf, tune (215rwkw) and some bigger brakes Have now brought my car to the 2000's with electric rear windows, door lights and wood trims |
01-09-2012, 08:35 PM | #5 | |||
mind went straight to thinking sixtys model xr (doing a custom job) not veriant xr(6/8)
02-09-2012, 11:33 AM | #6 | ||
wild xr8
so if i get a fairmont dash loom a should be pretty right?
02-09-2012, 02:52 PM | #7 | ||
yep, get a complete EL Fairmont dash loom .
an EF Fairmont one is different, (connections for bem etc)
02-09-2012, 07:33 PM | #8 | ||
wild xr8
would i need to swap the bcm or keep the original xr one??
03-09-2012, 09:34 PM | #9 | ||
wild xr8
This is the interior i got
04-09-2012, 06:35 PM | #10 | ||
Peter Car
I'll swap you my drivers seat for yours
Mines looking a little shabby, that one looks in excellent nick. |
