Old 07-08-2012, 08:47 PM   #1
dieseltrain79
Default Help with Torque wrench for au front hub nut
Changing hub on wife's AU and need a torque wrench capable of 300nm or 225 lbt to tighten it up to specs .
Is there anywhere you can hire one ? I've found 1 place for $100 , Could probably import one for that .
Cheers . Am located in western Sydney , seven hills
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 08:59 PM   #2
BHDOGS
Default Re: Help with Torque wrench for au front hub nut
If you mark the distance the nut is in on the thread you can just tighten it up with a Breaker bar and youd be fair close to the right torque
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 09:03 PM   #3
dieseltrain79
Yeah That's not a bad idea if I can't find a hire place . Maybe mark it and max out my 150 unit and breaker bar till mark , least that way I know it's 150 min
Old 07-08-2012, 09:16 PM   #4
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
I'm looking for one myself. Best I've found is around the $180 mark.
http://www.austools.com.au/specialty.../prod_894.html
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 09:36 PM   #5
MrEL
Sick Puppy
MrEL's Avatar
You cant be serious with that comment can you?
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2012, 09:37 PM   #6
dieseltrain79
I've got a good breaker bar and 1.5m pipe , so no issue tightening it . Just I've read of failures from incorrectly torqued nuts .
Old 07-08-2012, 11:32 PM   #7
saber
Granted this method won't torque the nut to exactly 300nm, but will something go horribly wrong if you tighten the pac nut (or hub nut) to say 280Nm when the spec calls for 300Nm?
saber is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2012, 12:29 PM   #8
dieseltrain79
Thanks for the advice , contacted a friend from T & E Tools at Pendle hill and sorted me out .
They have everything .
