Old 12-05-2012, 03:20 PM   #1
Bunyip04
Think Heavy..
Bunyip04's Avatar
Question Pads & Fluid.
G'day, just wondering what brake fluid you guys reccommend for BF II XR8,
out of the usual Castrol super dot 4, PBR red dot etc pelase?
And i'm chasing some good but not great pads for the rear standard brakes, in conjunction with EBC reds up front also, please?
Appreciate the help in advance!
Cheers Mick.
________________________________________
07 BF MkII BOSS 260 XR8 6spd manual! EGO
There's no replacement for displacement!!!
Handling: Bilstein Shocks with King springs all round, Whiteline 27mm front swaybar & 22mm rear adj, upgraded PBR rotors, calipers and braided lines all round with Bendix Ultimate pads.
Go Fast Bits: Herrod C.A.I with K&N 4" pod flter, Herrod Helix spacer, Herrod oil breathers, Tridon 72c thermostat, Herrod 2.5" stainless cat back zorst.
Bunyip04 is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2012, 12:14 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Pads & Fluid.
Cheers Mick.
The AP Racing 5.1 fluid is what we like to use and is $20 per bottle for 2 or more and rear pads for street use are from $80 to $120.Do you have the rear 328mm vented disc or the solid 303mm as the rear pads are different.
MATTHEW PEARCE
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 14-05-2012, 12:16 PM   #3
[THOMMO]
[THOMMO]'s Avatar
i also wanted to find this out, i was told to only put dot4 in my FG but i would like to goto a higher type fluid as i will be tracking this car. You can let the 4 and 5.1 mix though, yes?
[THOMMO] is offline   Reply With Quote Multi-Quote with this Post
Old 14-05-2012, 03:09 PM   #4
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Use the 5.1 but bleed it through the system until all new fluid is visable.
MATTHEW PEARCE
Phone 02 9609 1101
Old 14-05-2012, 06:18 PM   #5
Bunyip04
Think Heavy..
Bunyip04's Avatar
Pretty sure the rears are the vented 328mm, will have to check, what type of pads?
Old 15-05-2012, 11:51 AM   #6
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Funny enough Bendix 4wd pads are great for the rear of these with the 328mm set up or we have TRW or Remsa also available.
MATTHEW PEARCE
Phone 02 9609 1101
