13-04-2012, 12:07 AM | #1 | ||
Sick Puppy
Hi all
I have a set of extractors off a XR8 with the 200 motor here to fit to my missus's 5.0 Series 3 Ghia. Its currently stock as a rock with the charming crush tube headers. Question is before I pull it apart is are the extractors a direct bolt up replacememnt for the crush tube headers to the facotry Y piece? I dont want to have it all pulled apart to find that I have to have it all modified to suit. We have had a single 3" system fitted not long ago and its now time to make it earn its keep with some new pipes. So are they a direct swap with the factory manifolds or will I need to get stuff moded to suit? Cheers |
13-04-2012, 12:41 AM | #2 | ||
Sick Puppy
My mistake they are actually the 220kw extractors.
13-04-2012, 12:52 AM | #3 | ||
Powered by Ford
I would say yes they will fit, only a guess though going on the theory that the standard cats on V8's all should be in the same position for off the shelf cat back exhausts etc.
13-04-2012, 06:22 PM | #4 | ||
They should, but you'd be best off getting them modded below the join to 2.5", and a pair of hi flow cat converters.
See this thread here: http://fordforums.com.au/showthread.php?t=11334302 |
