Old 17-02-2011, 10:35 PM   #1
Neale
Neale's Avatar
Default Custom Tune for LS Focus 4cyl
I was wondering if anyone here has had a custom tune done for a stock Duratec-HE from the LS Focus.
Ive always been sceptical of how mutch difference a custom tune makes to a stock motor.
Ive since herd from a few people that have done it to different cars & they rave about how mutch difference it makes.
So whats peoples ideas & do you think its worth the cash???
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2011, 02:02 PM   #2
somers181
somers181's Avatar
What are you looking for in the custom tune?????? Better performance, better economy and how much extra is it to have done.
I found when i had my LS serviced the real difference appeared to be the type of fuel i was using and the tyres i had fitted (potenza's)......
Capri Car Club of NSW,
Keeping the Legend Alive since 1985
somers181 is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2011, 04:35 PM   #3
DJM83
Barra Turbo > V8
DJM83's Avatar
How does a tune benefit an N/A engine? Are there many parameters that can be changed? ie like a F/I engines boost map.
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
Old 18-02-2011, 04:42 PM   #4
photn
AFF Post NAZI
photn's Avatar
Neale, there are not many things you can do in the way of custom tuning. I do know that Spiro at autotech got an extra 40kw from an XR4 when he tuned it.
He is in granville. Despite my issuess he is probably the best custom tuning guy out there.
If you want an already created tune, you can go either Dreamscience or BlueFin.
I used to have a bluefin on my focus and it was superb.
Old 18-02-2011, 07:49 PM   #5
Riksta
Captain Malcolm Reynolds
Riksta's Avatar
I'd rather get all my intake & exhaust updated and set, then tune it to suit them.
Currently: 2014 Mazda6 GT (Daily) and 1999 Mazda MX5 (Fun Car)
Previously: 2001 Ford Escape XLT; 2010 MC Mondeo; 1984 FD LTD; 2001 AU2 Falcon Forte; 2005 LS Focus Zetec; 1988 RE Colt; 1982 RB Colt; 1974 KE20 Corolla
Originally Posted by Nikked
Riksta likes VN's so much, he has the ashes of a VN in a jar on the mantle piece, a vile of VN engine oil hanging from his neck and a BT1 build plate locked up in a safe, buried under 6ft of concrete.
Originally Posted by Day-mow
pretty much what has happened here is i trolled you. and it was fun.
Riksta is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2011, 11:15 PM   #6
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
How much you do you want to spend?
Buying anything from this catalogue would be nice:
http://www.cosworthusa.com/store/pc/...?idCategory=20
or even http://www.newedgeperformance.com/fo...zevengine.aspx
I'm not sure how legit these guys are:
http://www.bulletperformanceracing.c...-Focus-NA.html
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2011, 12:40 AM   #7
DZFord
DZFord's Avatar
Just a word of caution when buying parts from the US. Not everything from the US Focus fits our Focus. For instance, that 67mm throttle body is cable driven, whereas our throttle body is drive by wire.
Bullet Performance Racing got a good review on the XR4 forums. Sign up there if you haven't already, then do a search and check it out. BPR is the only shop out there advertising SCT tuning for the Focus online.
Old 19-02-2011, 11:05 AM   #8
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
Seconded. This is definitely the way to go about it.
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2011, 05:40 PM   #9
photn
AFF Post NAZI
photn's Avatar
This is true,
but if your in VIC then just go to Herrod Motorsport as he is the Australian Distributor for SCT. If your in NSW, Tunehouse and Autotech Engineering are the two.
Old 21-02-2011, 07:16 PM   #10
Neale
Neale's Avatar
40kw from a tune is pretty impressive, were there anyother mods done before the tune??? Also would it make a difference in Torque aswell??
Thanks for all of your advice guys, the main thing I would like from the car is a bit better performance, without loosing a great deal of ecconomy.
In other words make it more efficient. I dont really want to go crazy on the mods beacause I dont want to spent thousands on the car. But I was wondering if I could do a few minor mods to make the most of what I already had.
Old 21-02-2011, 08:32 PM   #11
DZFord
DZFord's Avatar
40kw would be a massive, if not impossible gain from a 4cyl NA engine, tune only. I am sure there would have been supporting mods.
Neale, you don't need to spend thousands to get a bit more out of your car. I'd start with a K&N panel filter, with the intake resonator removal mod, then the next step would probably be a cat-back exhaust (2.25" is preferable), which could be custom made at an exhaust shop. Couple those mods with a tune and you'll be guranteed better economy and a little more power.
Old 23-02-2011, 04:12 AM   #12
photn
AFF Post NAZI
photn's Avatar
Hey Neale, I didnt get specifics on what was done to the car - spiro didnt really go into it, but i would imagine there where intake and exhaust mods to suit.
If you want just a little bit of extra go, my suggestion would be a cat back and a panel filter or K&N apollo. then simply get a bluefin or a Dreamscience for 800ish and your set to go. a custom tune from Spiro is 1600 including Xcal3.
I had these simple mods on my LR before i went SC, i noticed that the fuel economy was greatly improved (6.8-7.2) combined. I even pulled a 16.4 down at the drags with intake and exhaust mods only.
