Old 28-07-2010, 01:21 AM   #1
Bradski
98 AU Futura
Talking Can Series 2 engine go into series 1
My AU series 1 has done 305,000km (just bought it a month ago), has got 5 to 6 hairline cracks in sump and transmission is starting to wine (the reason so cheap I guess).
Wreckers are chasing $120 just for the sump. I have just found a whole car for $300 but its a series 2 with 160,000km on clock, There is nothing mechanically wrong with engine or transmission, so is it as easy as unbolt series 1 and then bolt in series 2 engine and transmission?
Bradski is offline   Reply With Quote Multi-Quote with this Post
Old 28-07-2010, 03:13 AM   #2
JC
Miami Pilot
JC's Avatar
As long as they are both either a Forte, Futura, or Fairmont (ie not an XR6, or a Fairmont Ghia), then yes, you'll be fine. You will need to use the series one coilpacks and leads, or change the engine bay (or just splice coil pack) wiring to series 2 (AU1 coil pack sparkplug lead connectors are outies, series 2 onwards are innies, or vice versa). Alernator wiring plugs are also slightly different, but you can chop and change ancilliaries and/or wiring to suit.
Ford Performance Club ACT
Old 28-07-2010, 10:29 AM   #3
GK
Walking with God
GK's Avatar
Good info JC.
TPS plug is also different S1 to S2-3.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 28-07-2010, 10:32 PM   #4
Bradski
98 AU Futura
Thanks Guys
Mines is a Futura on gas and the Series 2 is a Forte (X Sport I think) no gas
So I guess it would be easier to take the whole wiring of the series 2 and leave it with the engine.
Are the computer the same, all will that have to been change as well?
Old 29-07-2010, 12:08 PM   #5
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
I did the reverse with our wagon,ie., put a S1 engine in our S2. The engines are exactly the same it's just the bolt ons that are different. The easiest way would be to pull both engines out and just sit the S1 engine along side the S2 engine and swap all the bolt ons over including the throttle body then just slot the S2 engine/trans ( now with all your S1 bits on) back into the car.
Bushbasher
PS. don't forget the engine mounts, apparently they're different too.
MINE- AUII Forte
Old 29-07-2010, 09:25 PM   #6
JC
Miami Pilot
JC's Avatar
Bushbasher
That's a good strategy too - depends on how old etc all the bolt ons are as to how much effort you go to. Engine wiring swap = big effort. Bolts on swap = less effort.
S1 ECU will run the engine fine whichever way you go.
Old 30-07-2010, 11:35 PM   #7
Auturbo6
The only thing u'll see!!
Auturbo6's Avatar
Just install all series 1 components onto series 2 engine and all will be well. I.E. coil packs, throttle bodies etc.
My car has launch control, simply BAM-BAM-BAM-BAM-BAM-BAM-BAM then select D for maximum respect, it bushfires the s**t house everytime!!!
Auturbo6 is offline   Reply With Quote Multi-Quote with this Post
