#31 | ||
From this article
http://www.goauto.com.au/mellor/mell...25768C00119D55 "Meantime, direct liquid injection (LPI) continues to be on track for the Falcon “in the latter half of 2010”, said Mr Burela." |
#32 | |||
Quote: Originally Posted by XCPWSF Is there portable speed cameras? Because coming home from school I noticed a cop sitting on the corner, with some box with buttons and knobs, with wires running into one of the big gum trees. Just practicing with the Tazer on a Koala? |
#33 | |||
#34 | |||
Cheers, interesting. A small car on LPG must cost peanuts to get around in. |
#35 | ||
This 'rumour' is absolute garbage. Every program encounters problems along the way, that's what the definition of 'engineering' is - solving technical problems. The LPI program is alive and well.
#36 | ||
Yes YOU
Little more to the rumour, apparently the engine does not pass emissions testing and the changes needed to get it to pass affects the reliability of engine.
#37 | |||
Lol!
2022 RAM Laramie 5.7 2023.50 Ranger Wildtrak 3.0 V6 Premium Pack 2024 Everest Sport 3.0 V6 Touring Pack 2024.50 Mustang GT 10A Grabber Blue Nite Pony Package. Due Aug 24. |
#38 | |||
Pity the fool
So this seems to be a calibration/mixing issue then. Seems fairly late in the piece to be finding out this sort of thing now though??
Fords I own or have owned: 1970 XW Falcon GT replica ![]() Proud to buy Australian and support Ford Australia through thick and thin |
#39 | ||
So how would this effect this agreement with Orbital:
http://www.orbeng.com.au/orbital/abo...ews/070509.pdf |
#40 | ||
I'm not taking sides on the "rumour" but we built another handful of LI's this week for the boffins to play with.(yes I work in the engine plant)
#41 | ||
Supercharged Mang-mobile
Sucks if the rumours are true but from past threads I have no reason not to believe WOTDAH.
09/00 VX HSV XU6 Build #0001 of 0171 http://fordforums.com.au/showthread....09#post5571209 -- Best E/T: |14.982 @92.12mph | R/T:0.013 | 60' 2.213| 330: 6.283 | 1/8: 9.624 @ 73.17mph | 1000: 12.529 | 25Deg, N/A Hum, 1010mb | Willowbank Raceway 7/12/16 Tickford EL Falcon XR6 RIP ![]() -- Factory Manual -- Best E/T: |14.991 @ 92.71mph | R/T: 0.607 | 60': 2.215 | 660': 9.665 |13Deg, 86%H, 1024mb, 184RA @ Willowbank Raceway |
#42 | |||
He has, the Knack..
2010 BF MKIII Falcon wagon "EGO" Workhorse, stock as a rock 2004 BA MKI Futura - Now the wife's For Show: 18" Kaotic Shadow Chrome, King SL all round, Cadence Amp, Kenwood 12" Sub, JL Audio 5x7's, Scuff Plates, MP3 Connector For Go: SVI LPG, K&N Filter, F6 CAI, XR6T snorkle, XR8 catback, Magnaflow metal cat, Pacemaker headers, Underdrive, Thermostat, Custom tune, DBA4000 Now with baby seat and toys 175.6 rwkw www.bseries.com.au/King_Nothing |
#43 | |||
Hoon On The Rise
![]() Join Date: Mar 2005
Co and the normal emissions are quite easily done on lpg, however nox is a challenge. perhaps one of the lps sponsors can shed some light and their thoughts? Cheers
![]() ![]() FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com |
#44 | ||
Some new diesels are using Urea injection to the exhaust to drop NOx emissions, adds $120 to the servicing cost every 20k kms as it has to be refilled. (on CX7s)
#45 | ||
just had a chat with my friend on the inside and he hinted that the issue is not due to reliability or the likes but
it is more the fact that the manifold is nearly freezing they are working on the spacing of the injectors from the manifold he also mentioned that the reason it is being kept under wraps so heavily is ford don't want to much known as it will hold people back from getting new cars as this new system is kick a$$ and they will loose sales in the interim till they get it right for release
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
#46 | ||
Well this thread is really keeping it under wraps isn't it...
#47 | ||
Wasn't this one of the problems in the "original" LPi system where the injectors were freezing. Maybe they'll have to install a secondary heating system to keep the temperatures higher.
#48 | ||
Trev
Like the old de-icing circuits on carburettors. Motorcycle had regular problems with carbs freezing up in cold climates, thus a coolant circuit was integrated across the fuel bowls.
Trev (FPV FG II GT-E thus the fully loaded burger with the lot as standard +Alpine/Dynamat fitout - 2 of only 4 ever made GT-E factory 9" rear rims - Michelin Pilot Supersports - Shockworks Suspension) |
#49 | ||||
Will the LI I6 have a plastic manifold?
#50 | |||
GT
CRICKEY I HOPE NOT . I'VE BLOWN A FEW AIRBOXES AND MUFFLERS IN MY TIME WITH na gas . I'D HATE TO BLOW UP A MANIFOLD AS WELL. ![]() |
#51 | ||
Fordaholic
This should never happen as the fuel is injected straight into the combustion chamber while the valve is closed.
#52 | ||
It will not backfire like the old systems
#53 | ||
Fordaholic
No the old system released the gas in front of the throttle body, so what used to happen on start up the computer would advance the timing as it would crank to make an easier start, so the inlet valve would be slightly open and a spark would come up the intake and ignite the gas at the mixer leaving you with the job of picking plastic out of you left headlight. The old saying of do not dribble fuel down the carbie to start it is basically the same thing, as that is when it is most likely to backfire up the intake.
#54 | |||
Peter Car
I think they are actually a glass fibre reinforced plastic though, which may help, and also because its injected basically straight into the intake ports it doesn't affect much of the manifold bar the manifold mounting face area that bolts to the head. Early E Gas BA motors had reliability problems, further R&D resulted in stronger conrods to stop them bending if the engine backfired, which also added another bonus by being able to use the stronger rod in the future XRT and F6. Further R&D will fix any potential problems the LI engines may have, it just takes a bit of time. Ford also have orbital helping with the R&D. Highly unlikely it will be a big enough problem to cancel it. |
#55 | ||
LPG Forum Moderator
The misinformation and poor guesses in this thread are unreal.
But then again some of them hold some truths. I hope its not true but I know they have some MASSIVE hurdles to overcome with the Vialle system. Their injection timing is not as good as some other systems so the injection will actually encroach into the period when the inlet valve is actually closed. That's one thing I know the system has a problem with. It may well be to a detriment of emissions. I don't know. And it may well be a real issue that their manifolds are freezing due to the configuration of their liquid injectors in the manifold. Again not an issue on other systems. i don't know I am clutching at straws here. But I do know they have some massive hurdles and I did say VERY early on in the piece that if Ford have this system ready by mid next year I will bear my bum in Burke street. It is a real shame though. Liquid injection on a OEM Aussie built car would be a real boost for LPG credibility as a whole. But if it doesn't run right it could be disastrous And its is not DIRECT injection LI. It is port injected. There is only one company that has a true DIRECT injection LPG system that does not shut of the petrol injectors. And that certainly has nothing to do with this thread.
#56 | ||
Fordaholic
I honestly thought that if they were doing true Li the it would be directed straight into the chamber not into the port, but then I suppose this would lead to implications on recasting of the head & then Ford would also do direct petrol as well, so pays not to assume.
#57 | ||
Peter Car
It is true Liquid injection, the LPG is injected. If it was direct injection it would be called LDI, as in Liquid Direct Injection.
#58 | ||
My thoughts, the lpg engine is producing too much NO and similar compounds. Fixing it, nfi.
#59 | |||
I'd think heat soak from the engine once warmed would negate bits freezing up, but yeah, that first couple of minutes while the engine is cold ![]()
Daily: AU1 Fairmont Ghia - 380,000 km (still going strong)
Weekender: 2009 G6ETurbo - 21,656 km - Seduce/Cashmere (The only shopping list I need: 4 Litres and a hairdryer) Daily: SZII - 56,000 km - converted to Tezza |
