Old 29-11-2009, 03:44 PM   #31
ST
ST's Avatar
Originally Posted by RG
No. I mean runs as in turns to 1440rpm. It's crazy.
http://www.youtube.com/watch?v=Z8ut5ND3agI
That is incredible, the attention to detail is insane. Has he built anything else?
2007 BF MKII XR6 CONQUER
ST is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2009, 07:16 PM   #32
ryanstev
ryanstev's Avatar
I'm still waiting for ceramic engines.
I read about it years ago, so could be wrong, but I'm sure the article I read said that due to the reduction in friction that a 1 litre engine had the power output of a 2 litre.
Ie double the power for any given size.
Also it needs no oil or cooling, so there would be weight savings there too.
My 79 Fairmont XC Project
ryanstev is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2009, 02:02 PM   #33
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
My concern would be the long-term stability of plastic components, and oxidation or brittleness.
Ryanstev, I've heard of the US Army investigating ceramic tank engines - this was to get rid of vulnerable radiators. The engines used liquid glass as a lubricant. Don't think they got past the experimental stage.
outback_ute is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2009, 02:22 PM   #34
Wally
XP Coupe
Wasn't it SRI that were experimenting with polymer engines?
Wally is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2009, 03:12 PM   #35
Fev
Fev's Avatar
I wanna track down one of those 2.3L Pinto engines!!!
318hp@9500rpm, 69KGS!!!! thats orgasmic
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery!
Insta@mooneye_ghia
White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly
Fev is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2009, 03:58 PM   #36
Fev
Fev's Avatar
Default The engine from the race car
Apparently these engines were priced between $15,000 and $17,000 each. This was back in 1980... ouch!
Found the images on http://forums.vwvortex.com/zerothread?id=2165621
Insta@mooneye_ghia
Old 30-11-2009, 05:58 PM   #37
ieatsports_cars
proud member of the MFCC
ieatsports_cars's Avatar
so if it is true, then i might be able to afford a 9.95 special GT from crazy clarks lol
ieatsports_cars is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2009, 06:00 PM   #38
Airmon
King of the Fairy's.
Airmon's Avatar
Are we referring to Plastics solely? Or are people confusing composites like Carbon Fibre with plastics?
It would be possible, but alot more expensive then metals. Alot of things would need to be looked at and I can't see it taking off anytime soon.
There is always constant development in the field of Polymers and in the future it may become viable. Manufacturers are already using polymers to replace parts that were traditionally metals (intake manifolds for example), but for cost, strength and ability to withstand high temperatures, at the moment metal still trumps all.
Ceramics would also have its benefits in an engine but ceramics are much more brittle and usually more dense and not suited to tensile stresses.
www.bseries.com.au/airmon
They say less talk more action,
I say more torque less traction!
Airmon is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2009, 09:41 AM   #39
Fev
Fev's Avatar
It's Trolon plastic polymer, developed 30 years ago. That race car easily handled a 5 hour race at 9500rpm so i don't see why it would be too hard to re-create nowdays with our better technology
Insta@mooneye_ghia
Old 01-12-2009, 12:57 PM   #40
trippytaka
trippytaka's Avatar
Plastic is made from oil, oil is going to run out... faster if engine parts were also made from plastic. We should really think about making less things out of plastic.
trippytaka is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2009, 04:59 PM   #41
aussie muscle
aussie muscle's Avatar
Plastic is also recyclable :alien2:
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2009, 06:38 PM   #42
Bossxr8
Peter Car
Bossxr8's Avatar
And metal isn't ?
Old 01-12-2009, 09:47 PM   #43
xtremerus
FG XR6T trayback
xtremerus's Avatar
xtremerus is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2009, 10:27 PM   #44
trippytaka
trippytaka's Avatar
True, but isn't it only certain types of plastics thatv can be recycled? Would using plastic in an engine change composition (through extreme heat etc) and subject it to contamination? It might add wuite a bit of cost to the recycling process.
Dunno, not sure. Anyone?
