Praise da lord,Henry Ford
as title says my xr8 makes a growling noise and vibration when slowing down. only happens between about 30-40kph regardless whether im braking or just coasting. replaced front rotors/pads about 3000kms ago.
could it possibly be front bearings? or worse, diff? any thought would be much appreciated |
#2 | ||||
AU DIE HARD
![]() ![]() Join Date: Nov 2005
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... ......................... Quote:
manual
96000km just had a wheel balance, didnt fix it it hard to tell whether its coming from the front or the rear |
could be handbreak shoes?
Critical Thinker
possibly your tire type. Certain tread patterns can cause particular vibrations.
Also check your uni joints? Could it be also wheel bearing noise?
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
tyres have been noisy since new(about 12000km ago),the fronts are very feathered on the edges of the blocks.
replaced rear wheel bearings about 10000km ago. havent done fronts. uni's are good. diff seems to have fair bit of backlash though. just picked my parents up from the airport, seemed to be worse when it is loaded up making me think it could the diff or gearbox. |
#7 | |||
Critical Thinker
Monsoon SIII XR8 220
Check the harmonic balancer too. I had a bad vibration at 1500-1700rpm which was most noticeable when decelerating. Threw on a new one and she's sweet as.
Cheers, Simon |
