#1 | |||
Hey, just wondering what the best way people have installed amplifiers under their seats. Am about to embark on a setup change in my ute and as a part of that wish to put the amps' under the seats to get me back some room behind the seats.
Nathan 2005 FPV BF Super Pursuit The new toy (now sold) The SP The old ute (sold) www.aufalcon.com/nc1183 Build Thread Quote:
I ♥ EDM
![]() Join Date: Aug 2006
It would double as a seat warmer too :hihi:
But seriously, I spose you could screw it into the frame that holds the foam in, depending on the size of your amp. |
#3 | |||
Was meaning more on the floor under the seat then actually on the seat.
I ♥ EDM
Well AFAIK there's nothing that one could accidentally screw into on the floor, so I don't imagine any problems.
The Monty
if u decide to do it to the chair, find a series 1 fairmont with the cd stacker under the chear and take a look how thats held up/in
THE Fairmont Ghia 75th
your fine mounting it under the seat but definatly dont mount it upside down as all you will do is cook the amp as well as the passenger's a**.lol
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install. My Ride My Build Thread |
I had mine screwed into the floor under the driver's seat ... it was a Pioneer 600W 4-ch.
Look near the early pages of my AU build thread in my signature ... there's a pic of it peaking out from under the driver's seat. Was a tight fit. My sub amp was bolted to the trans tunnel ... on a flat piece of carpeted MDF (kinda false floor) ... between the subs ... it was solid indeed.
adrian
where did you guys take the 'auto on' power to the amp? ignition on? antena power?
T3 TS50 #17 275kW AU3 XR8 SVP 220kW |
#9 | |||
JMM modded EF
velcro is an easy option. amp must be mounted right way up tho otherwise itll overheat.
"She goes like a zirtek" WANT A FAST FORD RING THIS BLOKE V V Abbott Engines for HeadWork 20 years experience PH Rob on (07) 5526 3883
#10 | |||
JMM modded EF
your head unit should have a remote out wire. use that for auto on.
#11 | |||
All Bran = Regular Member
I got my velcro (not too sure how long the roll was... maybe two metre's?) from Bunnings for around $20. |
#12 | |||
adrian
#13 | |||
Stay Classy ™
#14 | ||
adrian
thats on the premium head unit, this is just the standard one, so no RCA outs or amp on wires...
#15 | |||
Stay Classy ™
#16 | ||
adrian
yeah, i was thinking the acc wire would do the job. don't like manual switches as they can be left on by accident.
#17 | |||
Depends on the amp, if your using one with speaker level inputs because you have't got RCA output, some of them have turn-on on signal detection.
#18 | ||
adrian
na, looking at hooking up my old Alpine amp/sub box, and just running a speaker-line level converter off the rears.
