24-12-2008, 06:27 PM | #1 | ||
Hi All,
I have a 91 TX5. I have a problem with the air conditioner, where the clutch drops out on fan settings 3 &4. The light comes on in the A/C switch on fan settings 1 & 2, but as soon as I switch to fan settings 3 & 4, the clutch drops out AND the indicator on the A/C switch also goes out. Hence it would appear to be a electrical problem. All fuses etc. have been checked. I do not have a wiring diagram so I would appreciate if someone could have a look for me if they have one or tell me where I can download a wiring diagram. Regards, Lee Geelong |
24-12-2008, 07:10 PM | #2 | ||
Over Thinker
is the system out of gas ... check for bubbles in the dryer glass
the system usually shuts down to protect the compressor if the gas is low
My car goes Brumm Brumm |
25-12-2008, 08:13 AM | #3 | ||
I believe not. It seems to be very reliable at fan settings 1 & 2, but it cuts off
very positively when going to 3 or 4. My experience with low gas is that , the action is more intermittant, as if it is a switch problem(??). That is why I would like to see a wiring diagram, to see what sort of circuitry is switched in on high speed settings & where the low gas detectors are etc. Regards, Lee |
05-01-2009, 01:42 PM | #4 | ||
More than likely a resistor. Usually positioned near the heater core.
05-01-2009, 01:55 PM | #5 | ||
I'm thinking fan speed switch here.
Normally, this switch has two sets of contacts: One that controls the fan speed (in conjunction with the resistor), the other enables the Aircon when the fan is switched on. |
15-01-2009, 03:41 AM | #6 | ||
Would go with ute83 on this one, the resistor more likely, but possibly switch.
How did you get on? |
