Old 16-06-2008, 10:06 PM   #1
GT_351
GT 351
GT_351's Avatar
Default What 60 ft time do you think I could do?
Hi guys stupid question, what are your thoughts, I have an XB 4 door GT rep, it has a toploader with 3.5's in the rear, 17 inch wheels with 235 45 17's and 392 rwhp, what 60 ft times do you reckon are achievable, I would be stoked with a 1.8 or a 1.9 or something, I am taking it to the drags next month and I have to reset and stiffen my springs because I get severe axle tramp, I will eventually try slicks down the track. What are your thoughts cheers guys.
GT_351 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 02:16 AM   #2
paddy351
Ford Nut
paddy351's Avatar
With the manual your 60ft times will suffer a little but 1.8 ,1.9 seem achevable , I am in the same boat. I am getting some tramp bars and some radial tredded slicks for Ford nats in September. Is that were you are going ?
Clevo + toploader = :
paddy351 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 11:05 AM   #3
jcxr
Tribal Elder
jcxr's Avatar
3.5s are going to kill your times, go a lower ratio, get some tramp/slapper bars, soft slicks, and you will be looking at 1.7-1.8s or better.
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2008, 11:59 PM   #4
GT_351
GT 351
GT_351's Avatar
thanks guys awww yeah I like the 3.5's it an awesome street ratio!!! See how we go. nah I am going to willowbank next month for a test n tune when its nice and cold, hoping mid - low 12's. What sort of shifter are u running paddy?
Old 18-06-2008, 12:01 AM   #5
GT_351
GT 351
GT_351's Avatar
Do you guys have something to hold the engine down apart from the engine mounts incase something breaks? I was thinking of making something up like a strap or a chain to bolt to my block to stop my engine lifting at takeoff and the aircleaner hitting the bonnet......what u reckon?
Old 18-06-2008, 01:44 AM   #6
paddy351
Ford Nut
paddy351's Avatar
I am running a competition plus hurst , i run 3.5's as well . Post up your results when you go out. - Pat
Old 18-06-2008, 10:00 AM   #7
XYLINC
XYLINC's Avatar
I have a brace that bolts from the passenger side head to the passenger side sway bar mount. Saves engine mounts.
XYLINC is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2008, 04:36 PM   #8
GT_351
GT 351
GT_351's Avatar
oh yeah i run a hurst indy how do you find the gear changes? I have to do some fine tuning with mine. That brace sounds like a good idea....see how we go. Thanks guys.... Mark
Old 18-06-2008, 06:22 PM   #9
XYLINC
XYLINC's Avatar
Are you running anything special in your gear set Pat, and are you running 28's or 31's?
Old 19-06-2008, 02:05 AM   #10
paddy351
Ford Nut
paddy351's Avatar
28 spline, richmond gears and steel Hat in a lsd . Just the norm !
Old 19-06-2008, 09:57 AM   #11
XYLINC
XYLINC's Avatar
Youre not worried about your axles for heathcote? I know I am.
Old 19-06-2008, 12:09 PM   #12
paddy351
Ford Nut
paddy351's Avatar
Not realy , if i was drag racing all the time then yes. The clutch on the other hand, a little ! But that is racing
Old 19-06-2008, 10:25 PM   #13
Rural 351
1000+ passes
Rural 351's Avatar
Default 60 foot
Good luck at the drags
You will find the axle tramp would go if you put on a set of Drag radials, Hoosiers, or other type of Drag tyre.
The engine brace on the front of the P/S head is good but you will find this will make the rear of the gearbox jump up as the engine is being held down from the front corner not realy a problem, but a bolt through the P/S engine mount with a old shocky rubber is a easy option but it means drilling a hole in the engine mount support.
The 28 spline axles are OK if the arent re-splines but the disc brake ones break easyer the the drum break ones
XY ute 1600+ kgs, normally aspirated pump gas 351 std stroke, cast iron 2V heads, toploader, drag radials, 11.524 - 119.48mph
https://www.facebook.com/DragRacingT...2067110055900/
http://www.cacklingpipes.com/100825_...250810_025.JPG
XA coupe naturally, aspirated Cleveland, full exhaust, 98 oct pump gas, drag radials, Manual trans, 10.664 132 mph
The faster youve gone the worse your attitude
Rural 351 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2008, 07:49 AM   #14
nugget378
Weezland
nugget378's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to impart knowledge in the technical areas.
It happens,the manuals seem to be hard on everything..
I just found a half stripped crown wheel and pinion and bent 31 spline billet axles in mine,and Ill need a new strange housing as well...
nugget378 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2008, 12:43 PM   #15
paddy351
Ford Nut
paddy351's Avatar
Was that from heathcote nugget ,that is no good. What's goodies will the new diff have ?
Old 20-06-2008, 05:00 PM   #16
nugget378
Weezland
nugget378's Avatar
Not sure when it happened,
I will have to get an aftermarket strange housing and some 35 spline mark williams billet axles,the centre should be ok with the bits I have in it..
Old 20-06-2008, 11:41 PM   #17
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
Hey GT 351, good luck at the strip...it's a lot of fun! With your 17" wheels and stiff low profile tyres you're going to easiy go up in smoke off the line if you even think about going hard with that much hp!! :
As soon as you spin, your 60's go up big time, so you're going to have to ease on the gas off the line and perhaps slip your clutch a tad without burning it. Just think "Granny".
I think an engine brace/chain is more important with slicks as they transfer all the twisting pressure back up the driveline towards the engine......your 17's will most likely spin and let the pressure off the line. It's still a good idea though, especially with a manual.
I'd prefer solid engine mounts myself (still have to get some), but in the mean time I fitted one of these from Competition Engineering.....called a Torque Rod. You can easily make them up with a few rod ends and steel rod + welder. Engine still moves around a bit, but perhaps I should tighten it more? Only used it a few times. Unclips in 10 secs for street use.
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2008, 01:45 PM   #18
paddy351
Ford Nut
paddy351's Avatar
Pretty good : but also a thing to keep in check. If i continue racing i will run washes and spit pins on my throw rods.
Old 02-07-2008, 02:00 PM   #19
Rural 351
1000+ passes
Rural 351's Avatar
Please keep us posted on how you go I dont want to be a smart *** but I think you will find your tyres will slow you down heaps. I reckon your 60s will be 2.1 or 2.2 slowing down what may be a low 12 car to a low 13 .If its got down low torque do a 3500rpm cluch ride let it bog down a bit and nail it, dont get to excited when you see that tree coming down or you will end up sitting there for longer than you want in a cloud of tyre smoke. good luck
Old 06-07-2008, 12:52 AM   #20
GT_351
GT 351
GT_351's Avatar
thanks heaps guys your help opinions are greatly appreciated, I am planning on going in a few weeks, will keep you's posted on how I go!
