Old 11-06-2006, 09:13 AM   #1
HSVETAR
Bring on the lion...
HSVETAR's Avatar
Default Falcon badge
The falcon badge on the rear, what are these held on by? I want to remove the Gli section, so it just reads falcon. DOes the GLi bit have any holes under it? How have other people cut off the word? Post pics of ones that have been done pls.
El falcon, 4.0, XR6 camshaft, pacemaker extractors, 2.5 inch exhaust with tri flow sports muffler, AU TE50 intake, with K&N panel filter, Advanti racing Stalker 17" rims, Sitting on Ultra Low King Springs, 'Gabriel' Ultras Lowered struts, NOW MANUAL, 3.45 LSD
9.694 @ 75.38 MPH at Mildura Drag Strip 1/8 Mile
XC Falcon project car underway......
HSVETAR is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2006, 09:35 AM   #2
EFDream
XRR83D
EFDream's Avatar
All the badges I've come across are held on with double-sided tape.
2003 BA XR8 Falcon - Lightning Strike
Mods: 18" GT's (Aftermarket), BF GT front end(FibreSports), Tint, Premo Sound, Leather, CAI, DBA slotted,
2007 Suzuki Swift - Pearl Red
Povo Pack
EFDream is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2006, 10:12 AM   #3
FalconHellMate
Gino
FalconHellMate's Avatar
EF / EL Falcons do have two holes in the panel beneath the Falcon GLi / Futura Badge
I am not certain but I think it is in line with the Falcon bit... perhaps sus it out at a wrecker or have a look at a new one at ford... The holes are for locating pins the badges themselves I believe are held on by the abovementioned double sided tape... There are however definately holes there....
FalconHellMate is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2006, 11:54 AM   #4
LukeyBAXR6
BA XR6
Nope, the GLI section is only held on by double sided tape (Well my EF one was).
Picture of mine is attached
Phantom BA XR6 Falcon
LukeyBAXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2006, 11:57 AM   #5
Holbrookau
OPT 20
Holbrookau's Avatar
The GLI part has no holes under it and can be safely lifted and broken off (with care).
Edit - Beat me to it Luke EF
'94 EF GLI
Dash Mat
Color-coded Ashtray
Polished Wheel Nuts
Holbrookau is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2007, 10:55 PM   #6
Conrad
I'm confused.
So the Falcon badge has 2 holes beneath it?
Does the Ford badge have holes beneath it?
It is always better to post in an existing thread than to create a new one.
Conrad is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2007, 10:57 PM   #7
b2tf
not here much anymore
b2tf's Avatar
Originally Posted by Conrad
I'm confused.
yes and yes. The holes are under the "FALCON" bit (so you can pull the GLI bit off and it will be fine, will be hard to though because the badge is made as one piece), and in the middle of the area behind the Blue Oval badge.
2024 F150 XLT
Old 21-08-2007, 11:00 PM   #8
Conrad
Cheers for the bad news b2tf!
Old 22-08-2007, 12:55 PM   #9
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Also note that if you want to replace the Ford Badge as it is moulded into the rear body with a slight curve so it can not be replaced with a flat badge...........
I changed mine with a custom made Ford LED Badge so it lights up at night
On my EF Monty it was not held on with Screws as Such more like Plugs.
If you want to be safe than sorry remove the rear tail lights (2 screws and pop the sides out) and have a look on the other side where the badges are mounted
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2007, 06:04 PM   #10
Conrad
I wanted to debadge the rear...
Old 22-08-2007, 06:12 PM   #11
krisisdog
krisisdog's Avatar
If you have a GLi or Futura you can snap that off, but Falcon and the blue badge have 2 legs each, so it'll cost a few bucks to get it debadged.
krisisdog is offline   Reply With Quote Multi-Quote with this Post
