Old 16-01-2007, 07:04 PM   #1
Terror6X
Formerly eawags
Terror6X's Avatar
Default AU bottom end ED xr6 head
From what i read this will work as my car has done 270k and is cheaper for a wreckers bottom end than rebuild.
What will the compression be''Anything to watch for?
Territory SY TX RWD povo pak 7 seater
Mods done: Terri intake pipe , 2.5'' exhaust, 20% tint AND some Daz magic fingers work.
Mods to come: Paceys, stall, under drives, MACE spacer and lowered.
Terror6X is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2007, 07:08 PM   #2
efgiar
rofl copter
efgiar's Avatar
if your not decking the block or head with an au gasket it should be fine. u can get away with a 20-40 thou off the head/block but wouldnt go much higher.
GQ patrol.
thats all
Old 17-01-2007, 01:57 PM   #3
Terror6X
Formerly eawags
Terror6X's Avatar
What happens with the power steer tensioner and running the water pump/clutch fan?
A std AU bottom end is identical to an AU XR6 one isnt it?
Old 17-01-2007, 02:11 PM   #4
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Have a look at this thread, it answers your questions, and is also a sticky in the E-Series technical area.....
http://www.fordforums.com.au/showthread.php?t=74982
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2007, 09:39 AM   #5
Terror6X
Formerly eawags
Terror6X's Avatar
Read all that. People say one thing then others say something else. Not very good
