Old 18-09-2006, 01:10 PM   #1
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Default Power Steering Coolers Standard Fitment?
Hey Guys,
After taking the front bumper off the EF to change the trans cooler, I noticed a copper pipe running across in front of the radiator. It leads to the power steering pump, and the other end goes to the rack. I've had trouble boiling the power steering fluid before and was considering fitting a cooler, so now I might run the power steering fluid through the old trans cooler instead.
My question is, do the coolers come standard fitment on E-series, or is it an aftermarket thing?
I've circled it in red in the pic below.
http://img.photobucket.com/albums/v4.../PS_Cooler.jpg
Thanks,
Aaron.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2006, 02:05 PM   #2
Psycho Chicken
Psycho Chicken's Avatar
Pretty sure only Sprints and GTs got them. At least in EA-ED.
Old 18-09-2006, 04:09 PM   #3
Walkinshaw
Two > One
Walkinshaw's Avatar
Darin's EL V8 has one, and im 99% sure my car has one.
Old 18-09-2006, 04:12 PM   #4
OED666
OED666's Avatar
i have seent that most ef-el's have the same cooler as you have, some have larger ones, similar to tranny coolers.
rare as on earlier e-series. i believe that ed futuras and fairmonts didnt get them as standard.
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2006, 04:14 PM   #5
niko
likes falcon's
niko's Avatar
they solved cooling issue with the ef and started using synthetic fluid, or the old and time to replace looking brown stuff
www.carhubsales.com.au
Old 18-09-2006, 04:21 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
6's have a much smaller one.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 18-09-2006, 04:24 PM   #7
EFFalcon
Last warning
EFFalcon's Avatar
hxxp://opax.swin.edu.au/~glenneaux/C.../Image1003.jpg
in that pic you can see it bent up out of the way.
thats the same thats on my EF GLi.
i rmeember when i was over there and you were 'practicing' you had issues with the power steering boiling.
i guess trans cooler is the easiest way to do it.
Old 18-09-2006, 05:58 PM   #8
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Damn, I thought was special for a minute :(
Old 18-09-2006, 06:10 PM   #9
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
this is what was on my mate's ED futura classic I6.
unsure if it was standard. car is auto and didn't have the tow pack.
pete j
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2006, 08:05 PM   #10
galapogos01
eec tweaker
galapogos01's Avatar
Aaron, my EF Fairmont 6 came with the same trans and PS cooler setup as yours. I off the ****y trans cooler for an ebay jobbie the other week, i never realised they were so tiny! Probably work great for the PS if you mounted it on the opposite side.
galapogos01 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
