19-02-2006, 09:18 PM | #1 | ||
EA Wagon
I think I am in need of some cheap speaker upgrades or similar in my car (EA Wagon)
as with the windows wound down and at freeway speeds I have to turn the stereo right up and the speakers distort :( rendering it pretty pointless, my plan at the moment is to buy some cheap 4" (they are 4" speakers in the doors right?) and see if that helps, unless you guys have any tried and tested improvements, I know the headdeck isnt the bestest in there but it cant be that bad! and really cant afford an expensive solution :( |
19-02-2006, 09:37 PM | #2 | ||
Lovin the Manual.
yep they are 4"
just find the best 4"ers u can get for what u can afford stick to brand names! =P dont get boss or somethin stupid get pioneer,alpine, hertz ect... good luck! |
19-02-2006, 09:39 PM | #3 | |||
Low and Loud
For a cheap GOOD Basic 4" I would recomment a Pioneer TSG 1040 4" speaker. It will sound quite nice and doesnt cost a fortune (around $50 for the pair?)
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
19-02-2006, 09:49 PM | #4 | |||
19-02-2006, 09:51 PM | #5 | ||
EA Wagon
cool, will have a look and get something that looks and feels good rather than just shopping by name, size of magnet look/feel of cone and that sorta deal, I take it its gonna be a simple case of door cards off and a easy change over?
19-02-2006, 10:20 PM | #6 | ||
Custom User Title
I have Jaycar Responce 2 way 4" in the fronts, they are ok until you reallly pump it.
19-02-2006, 10:31 PM | #7 | |||
EA Wagon
I cant wait to rip out the crappy paper coned ford stock rubbish and get soemthing semi decent in there, was born to tinker |
19-02-2006, 10:36 PM | #8 | ||
Custom User Title
JVC KD-SX985 running through a Jaycar Responce 4x50W Amp.
19-02-2006, 10:38 PM | #9 | |||
EA Wagon
19-02-2006, 10:48 PM | #10 | ||
Custom User Title
If you're still running the stock deck, I have a Clarion Cassette HU you can have for postage costs.
19-02-2006, 11:00 PM | #11 | ||
I had these, and I highly highly rate them, they are awsome speakers.. i had them running off an amp though..
400 Watts Max FR 40Hz-22kHz Impedance 4 ohms Two 4" midranges: * Carbon Kevlar * Super wide edge rubber surround. 30mm near 1.5" high temperature voice coil 10Oz magnet Two 1" mylar dome tweeters: * Neodymium magnet. Angle / flush / surface mount options. Two Xover networks: * 18dB/Oct. 2-way cross over network @4kHz. +/- 3dB boost/cut controls. RP: $165.00 |
19-02-2006, 11:08 PM | #12 | ||
Stidd what are they?
19-02-2006, 11:15 PM | #13 | ||
i seriously wouldn't bother with a 4" speaker. If you can afford it get a 6" speaker and get the metal cut out so they fit. Even if you only have a 4" grill on the doors, it will still sound better than a 4".
19-02-2006, 11:19 PM | #14 | |||
19-02-2006, 11:31 PM | #15 | ||
likes falcon's
find your colour door in an eb2 and bolt them on, u get free 6" speakers!!!! :P
or, slice into the door with tin snips and make the whole bigger
www.carhubsales.com.au |
20-02-2006, 12:27 AM | #16 | ||
I have Kenwood 12" Sub + and 6" 2 Ways in the Galant and they sound really nice. I like there gear for price and performance. Also, Pioneer make some awesome gear. Stick with brands that specialize in a field, ie not companies that make everything.
Listen to stuff too, a lot of car audio places have stuff on audio-demo, it will sound different in a car obviously, but you'll get a good idea. |
20-02-2006, 12:34 AM | #17 | |||
20-02-2006, 03:47 AM | #18 | ||
Ea 1990 with ef head
Location: recently relocated from gipsland to newcastle
I had the same problem i went for a spin down to super cheep got a set of explode 4in for 50 bucks and they go alright unless you really pump it and my head unit has the same out put.
20-02-2006, 05:57 AM | #19 | ||
You have got to be careful though, decent speakers expect a high power, clean output. Which a stock deck doesn't give. Theres no point in getting $100 100w speakers when the deck only puts out 5w, because its not enough to make the speakers work, thats how speakers blow, the amp craps itself and gives raw dc votage instead of signal. So don't touch splits without an amp, they're less efficient and require more wattage. When you're shopping for speakers find the ones with the highest db/w, thats the measure of efficiency, normally around 89Db/w, anything around 91+ is good. From memory phillips speakers are pretty cheap and efficient as they don't really worry about the aftermarket sales, just decent speakers for stock systems.
Ideally you want the deck or amp to put out more than the speakers nominal wattage.\eg what EAman said cheap sony speakers will do the job. (decks no matter what they claim, will put out no more than a clean 20w per channel, if you believe other wise, do you think that most of an amp is empty space? Or that whats in a 4x50amp fits in a deck in a space 1/16 of a size? It's all to do with the amount of power circuitry needed for that wattage, it can't fit in a deck with all the other stuff) Last edited by fo3oz; 20-02-2006 at 06:15 AM. |
20-02-2006, 06:06 AM | #20 | |||
20-02-2006, 06:12 AM | #21 | ||
the best solution, it to get a piece of 16mm MDF, cut it to shape, to cover the bottom section of the door, and mount 6X9s up front, with a seperate amplifier, to give them 100+watts a side...
any 4inch speakers are going to be pretty much the same as stock (volume wise) as the stock paper cone speakers are quite efficient... |
20-02-2006, 08:47 AM | #22 | |||
Dude, Kenwood even make a water purifier, not even an electric item. I do have an opinion on how to select a brand there, Pioneer make some other stuff too, other electronics tho, treat those two as an exemption. I do see how you've read it, but I could've included Sony to that rule too, but I reckon there stuff literally x-plodes. It still doesn't mean Kenwood can't make good stuff, or that I've contridicted myself.. But for the guy asked, and my rule still makes perfect sense to follow, ie: If you don't know what's good, stick with brands that specialize. |
20-02-2006, 09:20 AM | #23 | ||
hey guys, ive got fusion 4" splits in the front, i rate them, they go really hard with the rest of my system and never had any distortion! my system is listed before. do eb doors have 6" in them ?
[COLOR=Navy][FONT=Arial Black]_________________________________________ [CENTER]88 EA Fairmont Ghia - Super lows (all corners) - Shortened Shocks - Custom CAI - Clear Indicators - EF XR8 LSD - EL XR 6 Head - Jim Mock XR6 cam re-ground - BF XR6 17's - Advance Extractor's - Redback 2.5" sports exhaust - |
Thread Tools | |
Display Modes | |
