BF F6, APV SR3900
hey all,
once the rocker cover is off, what is involved in changin the lifters.. what exactly needs to be done.. i thought it was a matter of undoing all the bolts on the pedestals and just changing them, but ive heard the power steering pump and something about a tensioner..? thanks.. santo
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. Last edited by santoitaliano; 08-02-2005 at 06:00 PM. |
just rip off the rocker cover, undo the bolts and put the new stuff in. Don't have to do anything with the power steer or the tensioner. Just make sure it's seated properly over the guides or when you start your car, valve's will hit pistons and that ain't fun. Turn it over by hand first with a breaker bar on the crankshaft pully to check if anythings gonna hit.
And how the hell do you get EF lifters out of the rockers, the ones with the ****y little hole?
BF F6, APV SR3900
with my torque wrench, what should i tighten the bolts back up to?
cheers,
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
From memory it's 20-25 nm, I just set it to 23nm and went with that.
#6 | |||
Cruisin in my EL
BF F6, APV SR3900
hmmm.. just after closer inspection... a pedestal has some pretty bad wear from where the rocker rubs up against it.. this particular rocker doesnt line up to the top of the valve spring spot on like the others.. is this something to worry about?
cheers,
#8 | |||
Yes, definetly worry about it! it must be the early type EA rockers, they didnt have the shim, or the slot in the pedastall for the shim. these always wear out. there is 2 ways to fix it, pull it apart and get them machined flat then use copper shims to make up for lost material, or get another set of rocker gear. the second option is easier and means you could upgrade to the ED type which have the 11 mm lifters and the Shims which are less likely to wear out. |
#9 | |||
I set my rachet to FT and went with that ![]() |
Custom user title
ya just gues the tension dont ya.... when it gets easy to turn you have gone to far :>:>
#11 | ||||
#12 | ||
BF F6, APV SR3900
11mm lifters? so that means i would have to dump the new lifters i bought?
shit shit shit... why cant anything ever be problem-free.. lol lol there are like washers between most of the rockers and the pedestals, but i think a couple are missing (need to confirm)... grrr.. thanks
Did you buy 11mm lifters?
#14 | ||
Hey if you want new rocker gear I have a full set of EF stuff and a full set of EA stuff, the lifters in both are buggered though so you'll need new ones.
Sundeep |
#15 | ||
BF F6, APV SR3900
the lifters i bought are the correct ones for the EA MPFI... are they 11mm.. lol?
i'll check it out..
#16 | ||
Shoot.
I think the ones for EA-EB are 14mm and the ones for ED-EF are 11mm... Or is it the other way around? LOL
20V Turbo |
#17 | ||
BF F6, APV SR3900
sounds right.. 14mm..
so if i were to get a some rocker gear from a wreckers, i would have to get from an EA-EB.. not somtehin like an ED? cheers
#18 | ||
Other way round... EA lifters are massive compared to EF ones.
Where did you buy them from? Can't you return them? You can use any rocker gear, EA-EL, they all bolt straight up. I would avoid using series 1 ea, as that doesn't have the intermediate thrust washer between the pedestals. I got a complete set of EF rocker gear including lifters for next to nothing from JR's... cleaned a couple of the lifters, bolted it on. Easy as, and it's mega quiet too. Last edited by spope; 08-02-2005 at 03:58 PM. |
#19 | ||
BF F6, APV SR3900
too long ago to return them... just picked up rocker gear... it must be off something else cos the lifters are the 11mm jobs...
what should i do? can i change the rockers from the old rocker shaft to the new one, will that work? i want to do it now, so if anyone could help me out id really appreciate it.. add me to msn if you like: santoitaliano[at]hotmail.com
#20 | ||
BF F6, APV SR3900
do the ef lifters need to be shimmed also coz it has a cam?
:S
#21 | ||
Custom user title
yes you need to shim them
#22 | ||
BF F6, APV SR3900
okay.. im changing the rocker gear over to the correct ones tomorow..
does anyone know the correct shim size for a wade 952 profile cam? cheers
#23 | ||
the wade cams usually require double standard shims. i think there 1.8 mm thick for the ED-AU type shim these only come in one thickness. the EA-EB have 3 different sizes so no idea what you will need there.
#24 | ||
I was told today that I just needed another set of standard shims from ford to shim up the cam. This was the 1604-113 grind.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
#25 | ||
BF F6, APV SR3900
ok this is for an EA.. i dont knoe what size...
#26 | ||
BF F6, APV SR3900
think im an expert now.. lol
its all in... ill put the rocker cover on soon and fire it up.. cross you fingers! pray for me.. haha.. later santo
Thread Tools | |
Display Modes | |
