Old 03-05-2012, 01:56 PM   #1
whitesoarer
Default Improving fuel economy?
Hi guys
I've got an EB Ghia V8 that is my daily driver and I'm looking for any ways to improve my fuel economy.
I do ~60km a day.
About 90% of my driving is highway, cruising between 80-110kmh.
My current fuel economy is between 12-13l/100km.
Mods are - Extractors, 2.5" exhaust, EL GT snorkel. The car is a 5.0 auto with a 3.23 lsd.
Are there any simple/cheap things I can do to improve my economy, has anyone had any good results with J3 chips? any driving techniques that can help?
BTW Replacing the EB with a more efficient car is out of the question
whitesoarer is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2012, 09:47 PM   #2
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Default Re: Improving fuel economy?
That seems high for mostly highway driving
I have a 6 that's had a lot of work done to it together with a 3500 histall and mind is around that with mostly mountain driving @ 60klms/h - going up a hill with 3500 histall is like riding the clutch all the time
I would take it to a Dyno Tuner and run it up on the Dyno to see if it's stock tune and afr's are correct - obviously you service it properly, new spark plugs, new leads, fuel filter, oil filter, exhaust doesn't leak and cats aren't blocked
If you Dyno it they will be able to give you a better idea
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2012, 10:01 AM   #3
XF_Pilot
Also consider replacing the O2 sensors and maybe cleaning out the MAF?
My old XR8 (EL 1 so same engine as yours) had 3.45s and I used to get better fuel economy than that with the same mods so there is definately some improvement to be had.
XF_Pilot is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2012, 10:53 AM   #4
whitesoarer
Yeah it does seem pretty high fuel usage for the driving that I do.
I'll change the plugs soon - no idea how old the current ones are. Same with the fuel filter. The exhaust seems fine, the engine revs out cleanly (as cleanly as a E7TE headed Windsor can anyway) and it doesn't feel like the cats are blocked.
Can I clean the MAF using electrical contact cleaner?
Old 04-05-2012, 09:11 PM   #5
revcore
revcore's Avatar
Has anyone successfully cleaned their old 02 sensor and found better fuel economy?
My Ride...
2005 BA2 XR6 Magnet Ute.
revcore is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2012, 12:08 PM   #6
Psi-Pop
on the way to the RSL
Psi-Pop's Avatar
Pump the tyres up really hard? Used to work on a pushbike lol.
ED GLi - DOHC - GT42R - 2 Speed - 275 Radials- Moser 9"
8.9x@160mph+
Psi-Pop is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2012, 12:13 PM   #7
madwag
madwag's Avatar
I dont think you can really clean O2 sensors
WTB. Black BF front door trims, BF wagon books, terry ducting.
The Daily's Build.
http://www.fordforums.com.au/showthread.php?t=11349360
Weekender: '69 VW Notchback
http://www.fordforums.com.au/showthr...24#post4531824
madwag is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2012, 10:13 PM   #8
xgte
check your brake calipers arent sticky or frozen.
xy 351 11.78@118mph daily driver
xgte is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2012, 12:05 PM   #9
XF_Pilot
yes contact cleaner works on the MAFs, I use it on mine.
Old 07-05-2012, 01:55 PM   #10
whitesoarer
Tyres were 32psi front 23psi back, so I pumped them up to 40psi front 36psi back lol.
Cheers I'll give the maf a clean and see if it makes a difference.
Thread Tools
Display Modes
