17-04-2011, 03:31 PM | #1 | ||
as per the tital i need a pic of the tps plug and wires in a au v8, i am trying to rewire a e series plug to suit and dont really want to do the bodgy drill out the holes to make it fit...ta guys
meh why bother i have your lies on audio file.. |
17-04-2011, 03:39 PM | #2 | ||
ok done a bit of a serch and i have three wires grey with red trace grey with white trace and browish with white trace... can someone tell me what each wire is ?
17-04-2011, 04:13 PM | #3 | ||
Well after a bit of playing around it looks like grey/ red is the earth. Grey/ white is the test wire and the brown is the constant 5v wire..hope i am right..
17-04-2011, 06:57 PM | #4 | |||
AU DIE HARD
Sounds like your finding your own way through it If you do a search in the technical section 4 th one at the top of the page you should be able to source it .
http://www.fordforums.com.au/vbporta...article&id=788
17-04-2011, 07:10 PM | #5 | ||
Thanks Woosha.. I find that if i take my time and play around i can almost always answer my own questions but its always good to ask aswell.
going to look at the link now. Jay
14-06-2011, 03:11 AM | #6 | ||
howd you go with this one mate?
14-06-2011, 08:03 AM | #7 | |||
14-06-2011, 08:08 AM | #8 | ||
you'd be popular too
Out of curiosity, what is the voltage these are set at cause it seems you can't adjust the voltage on the AU plugs?
98 EL XR8II Manual E303 cam, ported gt40p heads, 1.7 rockers, high flow cats, Au220 TB, 70mm Maf, tune (215rwkw) and some bigger brakes Have now brought my car to the 2000's with electric rear windows, door lights and wood trims |
29-01-2012, 03:21 PM | #9 | |||
I'm running an AUIII 70mm TB on a Trick Flow upper and obviously had to modify the E-series TPS to fit, the plastic was too brittle and broke. I still have the AU TPS so I'm looking to do what you have done. What colour wires go to which pin (A-B-C)? Cheers.
1993 LTD V8, Trick Flow H/C/I, T5Z Manual. |
24-01-2015, 09:38 PM | #10 | |||
Had to drill the AU TPS out 0.75mm to get the adjustment required. Spliced both TPS wire sets into the AU TPS and Bang 0.98v Looks good and gives more bonnet clearance than the double TPS setup Took a while to find the info online, so hope this update will help fellow E series. Go the ford V8 |
25-09-2021, 08:30 PM | #11 | ||
Whilst I know this is an old post do you happen to have wire positions
Thanks in advance
Heart attack facts - will you recognise your heart attack? http://www.heartattackfacts.org.au |
25-09-2021, 10:34 PM | #12 | ||
Next upgraded Mk1 Leopard
he hasn't posted for a long time
26-09-2021, 02:43 PM | #13 | ||
Thanks
Thread Tools | |
Display Modes | |
