19-06-2007, 06:16 PM | #1 | ||
BF F6, APV SR3900
hey all..
really startin to need the dollars, think i might get more notice here... bbm manifold off an ef: $100 EF Twin Thermos: $100 Smartlock Bypass Module - $100 EL XR6 Manual ECU (brand new from ford) - $600 EF Alternator (110 amp) - $90 EF P/S Pump - $60 EF AirCon Compressor - $50 various bits and pieces just ask... i have an ef xr6 motor i think i will be keeping... pickup in pascoe vale... santo
Santo White APV SR3900 [WIZZRD] (Click Here) [/COLOR] Daily: 2006 Red BF F6 Typhoon Bluepower enhanced. |
19-06-2007, 06:26 PM | #2 | ||
Try eBay man, you'll probably have more luck there!
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
19-06-2007, 06:27 PM | #3 | ||
@jas_23_
what is the ecu no. im assuming the first 3 digits are 6TA
19-06-2007, 06:38 PM | #4 | ||
Sell the car I'll buy it, it's sick.
Sundeep |
19-06-2007, 07:45 PM | #5 | ||
BF F6, APV SR3900
ecu is ford part no
R96DT-12A650-AC or catch code 6TAC... i can not stress enough that this ecu has been purchased straight from ford a couple weeks ago and has NEVER been fitted to the car. The R in front of the part number signifies it is a ford re-manufactured unit and they will be no longer carrying them anymore. If you go to a ford dealer, enquire about this part, you will find there are 6 left in australia and they are $990 a piece.
19-06-2007, 07:46 PM | #6 | ||
BF F6, APV SR3900
Also for sale is an EL Air Intake setup, including airbox, filter and piping to the throttle body... need $90 for it...
19-06-2007, 07:46 PM | #7 | ||
Why'd you get it?
Sundeep |
19-06-2007, 07:53 PM | #8 | ||
MADED.6
ill take the thermos where are u.
im in werribee so if its not far ill come on the w/e. b4 i get them they work alright yeah. cheers josh.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
19-06-2007, 07:56 PM | #9 | ||
BF F6, APV SR3900
coz i got silly ideas in my head...
my plans were to drop in ef motor, hook up el xr6 ecu, pop a dizzy and a coil in, run smartlock bypass, twin thermos and el intake... i put the bbm up to my current engine, ran new water pipes, bolted it up, then realised that coz i have a build plated, original unique model, lol, that i should keep it relatively stock and not go to that extent of modifications. so now i will prolly rip my motor out at some point, whack the crank and head off the ef motor into my 3.9er keep current 3 belt setup and clutch fan and jut have a nice fresh motor...
20-06-2007, 09:01 PM | #10 | ||
Please use the For Sale section of Australian Ford Forums to sell items.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
Thread Tools | |
Display Modes | |
