Hey guys my 5 speed AU2 XR6 is leaking water from the firewall and onto the brake pedal...
Has anyone else had this problem and can you give me some tips on how to fix it? Its coming from above a bracket that is spot welded to the right of the pedal box, the bracket holds some wiring with an orange plug, see the pics... ![]() you can see the water dripping off the loom in this pic below: ![]() ![]() Also what is up with my pedals, are everyone elses bent like mine? the pedal box seems very flimsy... ![]() the clutch pedal is alot higher than my brake pedal too, should I try and adjust this out? ![]() |
Flairs - Truckers Delight
perhaps that avatar's not the best idea when asking for help
and lots of people have water in the footwell issues - in fact i think it's covered in the common AU faults sticky thread - otherwise there'd be threads and threads on this. a search might do you some good.
2006-2016: Regency Red 2000 AUII Ford Falcon Forte Automatic Sedan Tickford LPG "Millennium Falcon" Last edited by Mr Hardware; 05-08-2010 at 08:51 PM. |
i'd be looking at where the rust is in the third pic, as that is above the black wire harness, looks to dripping from there to the wires below
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
#4 | |||
that thread is 18 pages long, and I have done a search, seems most people's leak is from where the clutch cable enters the firewall, and there is a well documented fix for it (weld the crack and then reinforce) mine is not coming from there though, mine is coming from the far right hand side of the firewall, it seems under the brake booster |
nice calming avatar , lol , im thinking windscreen leak , then dripping onto that steel bracket , then onto the cables
LOL WUT
also sikaflex everything
#7 | |||
#8 | |||
BOSS Pilot
pretty sure this is a fairly common problem in manual au's. I remember when I had mine I tryed on here to find out what it was and lots of people had the same problem with no solution
Black BAII XR8 Ute Blue SY Territory Ghia Quote:
Cat be Still !!!
#10 | |||
Money Talks, but all i ever hear is it saying Goodbye!! |
#11 | |||
#12 | ||
AU Falcon Man
This was my exact problem... was causing the rear drivers footwell to fill up...
2015 SZ MkII Ford Territory TS Aero Blue, RWD Petrol, Standard Sat Nav. 2013 TF Ford Kuga Ambiente Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol. Was 2012 FG Mk2 Ford Falcon XR6 Swift Green,6 Speed Auto, Stock... 2001 AUIII Ford Falcon Forte Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior 1994 EF Ford Fairmont Gun Metal Grey, Lumpy Straight 6 |
#13 | ||
good post craig au i got the same problem
#14 | ||
Yeah i had the same problem as well... was like "no way, that wont fix my issue" when i saw that thread... was very humbled when it did...
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box| |
#15 | ||
fixed mine too
#16 | ||
XR6VCT
found it when wasing the falcon.....and after a huge smashing of rain filled up the rear footwell......this works great and happy to have a fix!
