AUII XR8
Hey guys,
I am just wondering what the length is of the Tremec T5 gearbox shaft is in a V8, measured from where the bellhousing meets the gear housing to the end of the input shaft? How much difference is their between the 6 and the 8 for it to be a problem? Any info is appreciated. Thanks Brett
Ford XR8 AUII Sedan, 5.6L Stroker Engine 250kw. |
AUII XR8
Anyone?
When I had both side by side I wish I had taken some photos. I did measure them roughly and from memory there was somewhere about 40-60mm difference between the two. The v8 one was longer than the 6cly one.
Hope that helps. I will double check tonight if I still have the measurements I did or if there is by chance a photo (Pretty sure I won't have any luck though) Cheers, Rhys
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
RIP...
I thought the difference is only about ~20mm.
V8 is longer.
. Oval Everywhere... |
#5 | |||
Youngling
HOPE OUR LUCK DOSENT END NOW!!
AUII XR8
Thanks bud appreciated it.
