22-05-2011, 07:38 PM | #1 | ||
Hello,
Just after any advice on what has happened to my car. Specs AU Series 2 ute, XL model 142,000km Driving my car home the other night, headlights on and was like my car had a surge of power. Next thing my instrument cluster light is bright, my low beams are now permanently high beams, I've blown my front left head light and my cluster is cutting out. I get home pop the bonnet and some fluid is in the engine bay near the battery, radiator, power steering pump etc. Only a small amount. Inspect the car, no leaking hoses, have fluid in all places that are needed. Left the car over night check it the next day. Start the car, cluster is working, give it a rev, cluster cuts out, no gauges working. Check headlights, parkers are parkers, low beam is high beam, high beam is parkers. At this point have also replaced headlight and noted that all interior lights are brighter. Leave car, come back, flat battery. Change battery over. still have the same problem. Any help? |
22-05-2011, 08:32 PM | #2 | ||
Sounds like your getting too much voltage. The regulator in your alternator maybe cactus and its also probably cooked/boiled your battery.
A voltage check is in order while its running.
AU XLS. |
22-05-2011, 10:30 PM | #3 | ||
I agree with Beer Baron, sounds like a dicky alternator.
If you are going to change it, I would suggest buying a NEW one and not a second hand one. |
23-05-2011, 01:29 AM | #4 | ||
Tickford 220kw Windsor...
Also check all your earths on the car, you may have a bad grounding..
E series falcons were notorious for it, Id expect that was still an issue in the AU's.. Not sure if the AU's had them, but the E series had one down near the transmission on the underneath of the cars floorpan.. That one was always a problem..
1972 Falcon XY GT 351 Clevo 4V Big Port, 4 Speed Top Loader Manual, Ice Blue.... 2002 Tickford AU Series III XR8 220kw Windsor, 5 Speed Manual, Liquid Silver... __________________ AU Tickford Facebook fan page.. https://www.facebook.com/#!/home.php...25060040851023
24-05-2011, 04:40 PM | #5 | ||
i basically had the same problem caused by a leaking power steering hose shorting out the alternator sending the battery flat while driving home. replaced the alternator battery and hose
24-05-2011, 06:24 PM | #6 | ||
turned out the alternator was completely cooked, was over charging battery while running and draining the battery while turned off.
Heated up the in car computer but as far as know no damage was done and is currently working. |
24-05-2011, 07:03 PM | #7 | ||
Overcharging for extended periods of time will greatly reduce the battery's life and in some cases cause acid boil and overflow.
Check your high pressure power steering hose for leaks, Wiggle it to check as well as just a look.
AU XLS. |
