Old 24-02-2011, 11:06 AM   #1
GreenR
GreenR's Avatar
Default Driving without ICC
Hi there Fadi.
I am in the process of changing my ICC over. I have plugged the blue BEM into the car so I can still drive my car. However I noticed none of the cluster works.
As It is going to be quite a few days until I install the new complete ICC and take it to Ford to get coded, is there a way to have the cluster working in the meantime? Or if I put in the new ICC will the cluster work even though it isn't coded to actually function properly by Ford yet?
cheers
GreenR is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2011, 07:30 PM   #2
GreenR
GreenR's Avatar
More specifically its only the tacho, speedo, and temp that is not working
Old 25-02-2011, 02:28 PM   #3
FADI75
Sponsor
Originally Posted by plarazza
Hi there Fadi.
cheers
hi
as long u use ur old bem and it on new one, and remote sensors for central locking the sits on top of ur old ICC, it should work appart from the coding issue, and as long the icc you are fitting has the same specs off the ur older ICC
cheers
ASL
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
