28-12-2008, 08:45 PM | #1 | |||
Back to Le Frenchy
Well since this gets updated regularly I'll just make it easier and leave the last post with the links as the current one.
Look below for all your AU need to know's.
12-03-2009, 10:40 AM | #2 | ||
Sales Representative
Not sure where to put this... but its useful info anyway :P
17-05-2009, 11:47 PM | #3 | ||
New additions to the Technical Section:
AU Falcon Torque Specification - Interior AU Falcon Torque Specification - Transmissions AU Falcon Torque Specification - Brakes, Steering & Body AU Falcon Torque Specification - Suspension AU Falcon Torque Specification - I6 Engine AU Falcon Torque Specification - V8 Engine AU Falcon Torque Specification - Engine Ancillaries AU Falcon Globes Reference AU Falcon PID Codes AU Falcon ECU Identification Searchable Database of Diagnostic Trouble Codes (DTC's)
26-05-2009, 10:45 AM | #4 | ||
29-06-2009, 09:24 AM | #5 | ||
Is there any type of head unit to replace the original premium soun d in a au fairlane and able to plug in from same loom??
Thanks |
05-08-2009, 02:38 AM | #6 | |||
Lost Boost Gained Class
U CAN GET A WIREING HARNES FROM ANY CAR PLACE that will fit a AU
2006 BF Fairmont Ghia
2001 AU Falcon |
24-12-2009, 02:38 PM | #7 | ||
Surprised this isnt already here:
HOW TO CHANGE FUEL FILTER http://www.fordforums.com.au/showpos...3&postcount=37 |
10-01-2010, 12:11 AM | #9 | |||
AU DIE HARD
Just a note for those who wish to contribute to this thread just post your help in the normal part of the Au forum and we can cut and paste the link to this section ,which will avoid havening to sift through pages of How to s to find the rite thread. Keep up the good work gang :lookedat:
........Age and treachery will ALWAYS overcome youth and skill....... CORTINA 250 2V POWER soon to be AUXR8 Windsor pwrd .............WINDSOR WARLORD WHO CARRIES THE CLEVO MAFIA AND BROKEN BOSSES... .................................................. Quote:
08-02-2010, 05:09 PM | #10 | ||
Critical Thinker
I found out that Camtech have a new website and now show all their off the shelf grinds for the AU.
http://www.camtechcams.com.au/ford_6cyl_elau.html
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
24-02-2010, 02:30 PM | #11 | ||
this is probably a small problem but it annoyed the crap outa me!
if you dont know it simply call your local ford dealership and ask about radio codes, they will transfer your call and they will ask you your VIN number and the name the car is registered and they will tell you. i know it would have been usefull knowing this instead of reading the whole manual to my car : |
18-06-2010, 10:59 PM | #12 | ||
Sure Im not the first to realise but the majority of those links are dead now because aufalcon.com went away. Possible to get them hosted and linked to here?
30-07-2010, 06:27 PM | #13 | |||
AU DIE HARD
15-08-2010, 08:07 PM | #14 | ||
I drive way too much...
The AU exterior mods link doesn't work.
AUIII Straight LPG Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat |
15-08-2010, 09:42 PM | #15 | |||
AU DIE HARD
06-03-2011, 09:07 AM | #16 | |||
AU DIE HARD
Just added a few more threads keep up the good work gang and let us Know if there is any we have missed
19-03-2011, 08:44 PM | #17 | ||
The throttle body cleaning pics are down, is there an alternative thread that shows how to clean it?
EDIT: I knew there was one somewhere. GK's tute: http://www.fordforums.com.au/showpos...2&postcount=48
AUIII Straight LPG Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat Last edited by atomiclord; 19-03-2011 at 08:54 PM. |
01-04-2011, 10:29 AM | #18 | |||
AU DIE HARD
Miscellaneous FUEL ISSUES FUEL PUMP .................................................. .................................................. . .................................................. .................................................. Link to the AFF Technical documents, there is a heap of info in here that you WILL find useful,this also includes some how to s Mods that don't work Some AU myths and facts Remove keys form boot with LPGt HOW TO's from AUfalcon.com.au HOW TO: Cleaning power window switches HOW TO: Upgrade your CAI CAI Install help HOW TO: Remove shifter surround/replace selector globe HOW TO: Spoiler removal HOW TO: Remove / refit side repeaters HOW TO: Cleaning the Throttle Body HOW TO: Installing footwell courtesy lights HOW TO: Changing oil and filter HOW TO: Painting brakes HOW TO: ECU reset process HOW TO: Remove & replace rear brake pads and rotors Look here for AU V8 mods, tips, tricks and help AU V8 common questions AU XR8 Intake pipe mods AU XR8 coil packs If it's an I6 you have, look here How To I6 Water Pump Replacement How to change your AU I6 Cam AU I6 HP vs VCT Brakes & Suspension - If it has anything to do with stopping or making your AU turn, it's here! Whoosha's Handbrake Adjustment guide Difference between standard and Premium brakes Front hub/rotor replacement AU IRS shock mount replacement Info on IRS IRS Hub & Axle Replacement The complete AU1 to AU111 brake conversion Swaybars Interior - If it's inside your AU, check here How to - changeover interior door handles How to - replacing door actuators How to - removing headlining How to - install console rear courtesy lamps How to - change gear shifter and surround GK's "how to" changeover double din stereo head unit Instrument cluster LED's Door trim removal guide Leaking windscreen fix Height adjustable aerial/centre fascia removal How to change manual gear lever Difference between standard and Premium sound Steering wheel removal/replacement Water in cabin issues BA/F interior into an AU Uncle Ken's seat repairs Uncle Ken's Grab handle guide Bushbasher's Climate Control Fix / Offer Exterior - If it's on the outside, it's here Whoosha's guide to painting car parts AU Rust issues Painting your headlight surrounds AU exterior modifications guide Replace exterior mirror S1 grill options Clear side indicators Here we have some ECU and electrical threads Speed limiter Auto trans Power v Econ modes HOW to replace Plugs, Leads,& Coil Pack -------------------------------------------------------------------------- Thanks to; Peuty The Monty au302s3 Whoosha Superroo AUbigfoot RussW Grand Pa Spec AU Uncle Ken AU11Pursuit for contributing to the list.
02-06-2011, 05:13 PM | #19 | ||
ROCKING THE EL FUTURA
guys i had a prob with determening what king springs suit my car and another forum member kristo gave me this link, so im posting it up as a guide for people with the same question.
http://www.kingsprings.com.au/catalo..._catalogue.pdf
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
25-04-2012, 09:05 PM | #20 | ||
Any Info available on how to remove the cluster?
FG2 XR6T KIA Cerato 2022 Kawasaki Z900
26-04-2012, 09:29 PM | #21 | |||
not here much anymore
Pull out the blanking plate where the fuel/boot release buttons normally are (ute has a blank plate cos it doesnt have them obviously) Use a long screwdriver or similar to get behind the cluster and gently prise it out from the dash, check that the clear plastic fascia does not get caught on the dash, if it does just wiggle it out The cluster should come out enough for you to reach the 2 wiring looms that go into the back of it. They are different sizes so you wont stuff them up when you put them back in. Cluster should now come out as a whole unit. To pull it apart (i.e. to change the background etc) use a small flat blade screwdriver to take the front plate off the back of the unit (easier to understand when you're looking at it). Be careful because the clips can be fragile and break easy. If you do take it all apart Id recommend putting some electrical tape all around it when you put it back together to keep dust etc from getting inside it.
RAM 1500
05-05-2012, 04:41 PM | #22 | |||
02-11-2012, 06:36 PM | #23 | ||
AUII XR8
Is there a wiring diagram for the AU, as I bought a push button starter kit and I need to know how to install it into my car via the ignition barrel and the 12v power system.
Ford XR8 AUII Sedan, 5.6L Stroker Engine 250kw. Last edited by GCPursuitPower; 02-11-2012 at 06:36 PM. Reason: spelling |
02-11-2012, 08:59 PM | #24 | ||
5.6L x 2 pilot
Check here:
http://www.fordforums.com.au/vbporta...rticle&id=1307 And here: http://www.fordforums.com.au/vbporta...article&id=788 Rayban76 has also installed the GT push button starter, so if you have any queries, send him a pm. Cheers Stu
07-03-2014, 03:05 PM | #25 | ||
Naturally Aspirated
Hi guys
Wondering if it's just a straight swap AU Fairmont leather seats into an AU3 XR8 sedan? cheers
2016 Ranger WILDTRAK PXII 6sp manual Pride Orange 1993 EBII Fairmont 4sp auto Biscayne Blue Previous Forms of Transportation: 1978 302 V8 XC | 1982 4.1L XD | 1994 ED Fairmont | 2000 AUII XR6 | 2002 AUIII XR8 | 2003 BA XR6 } 2011 SZ Titanium Territory | 2006 BF Pursuit BOSS 290 6spd manual #57 | 2003 BA Fairmont 5.4L 4spd auto | |
31-08-2014, 06:50 PM | #26 | ||
Next upgraded Mk1 Leopard
I think so, if the seats are powered you would have to power them up. Not sure the the wires are already there. Bolt wise they are the same\
UK
01-09-2014, 12:29 PM | #27 | ||
Naturally Aspirated
Cheers UK
I actually did this back in March. Got a seat of Millenium Leather seats from a Fairmont AU. The cable loom for the power seats was there already so it was just plug n play. Had some minor issue with the rear seat brackets being a different size to the XR. I had my local trimmer just swap the foam over.
05-12-2015, 02:54 PM | #28 | ||
LIFELONG DJR SUPPORTER
Is there a "How To" for replacing a Harmonic Balancer at all?
07-12-2015, 06:37 AM | #29 | ||
Bump.
10-12-2015, 07:32 AM | #30 | ||
Auto Nerd
You will need a puller that grabs the balancer from the inner frame so to speak. GG technics make one but they are pricey.
If you have an air gun you can take out the crank bolt easily, but usually most guns wont fit unless you take out the radiator. By the way, electro fans and accessories belt needs to be out. I am assuming that there are how to's elsewhere for these, but sing out if you need help. I find it quicker by hand. Underneath the inspection plate for the torque converter is a hole where you can access the ring gear. You can jam this up with a large screwdriver with one hand and using a breaker bar, you can crack the bolt. 22mm bolt. When pulling the balancer out, it will slide over the bolt, but not the washer. Take the washer out and put the bolt back in for the puller to press up against and you can get the balancer out. Change your crank seal if it is leaking. Silicone on the keyway of the crank, fit the new balancer and use the bolt and washer to press back in. 125nm is the torque spec and yes you will need to jam up the ring gear when torqueing the balancer bolt. |
